Go to Post As Shakespeare once said in Julius Caeser, "Cowards die many times before their deaths; the valiant never taste of death but once." - artdutra04 [more]
Unread 22-01-2014, 18:35
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
New Bimba cylinders leaking?
We just hooked our 3 new free cylinders up to our pneumatic system off board to check for leaks, and I discovered a problem with all 3. If I apply 60 psi to one port (I only checked the extension ports) with the other port open, it actuates but it leaks steadily (as in drains the system fairly quickly) past the piston seal and through the open port. It was leaking so fast I couldn't tell where the leak was with a soap solution, so I submerged the whole actuator and just watched the air flow constantly out. I tried a couple of old actuators and didn't have this problem, so pretty sure it's not a "design feature" that I never noticed before (and pretty sure I would have noticed my system draining unexpectedly). It seems to hold at about 20 psi so at some point the seal seats, but has anyone else had this problem this year?
Close enough to taste it, too far to reach it
Unread 22-01-2014, 18:46
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: New Bimba cylinders leaking?
What bore are you using?
Unread 22-01-2014, 19:56
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
Rookie Year: 2011
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
Are you using Teflon tape or a gasket to seal the connections?
Unread 22-01-2014, 21:45
DonRotolo's Avatar
Back to humble
FRC #0832
I'm not sure you can use Teflon Tape on the piston seals inside the cylinder.
No Gary, they are not supposed to leak internally, and if I had that cylinder I'd condemn it as faulty.
Unread 23-01-2014, 14:35
Rookie Year: 1998
I spoke with Bimba, they are sending 3 new cyllinders
