Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 22-01-2014, 18:49
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Crio not responding to code deployment
Hey all, so we have reached that part of build season where the Crio starts acting up for no apparent reason. The issue is that when we try to deploy code to the robot, the deployment progress stops at "waiting for the target to respond". Sadly the target never responds, and we have reboot the crio several times or in most case, re-image it entirely.
I have no clue where to begin on troubleshooting this, but have found that it does it regardless of whether the driverstation and dashboard are open on the same computer doing the deployment or if they are on two separate machines. We have tried swapping out the crio with a different one, but the problem persists.
Is there an update for labview out or something that we've missed?
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
