Smoked Polycarbonate
My team wants to use 1/8 black smoked (http://www.mnpctech.3dpixelnet.com/p...ctech.com6.jpg) plastic sheet to protect our electronics and for the all important style points. What we were wondering is where can you get it? All I can find on McMaster is solid colored sheets. Let me know, thanks.
Re: Smoked Polycarbonate
www.eplastics.com carries the product you are looking for but its not inexpensive. You may wish to see if you have a "local" plastics distributor as your desired sheet size is going to influence your shipping costs. That said I've had no issues ordering films from them in the past but we generally order material that borders between film and sheet (1/32" and 1/16" usually).
You might also give http://lairdplastics.com/ a shot.
Gray tinted semi-clear impact resistant polycarbonate is available from McMaster under part numbers #87225K21 up to #87225K27, depending on the dimensions you want. Here is a url of the smallest available size.
Regardless of what you purchase, make sure what you get isn't acrylic or you're gonna have a bad time. |
This. It's better to know now than to know after the robot comes back to the pits with it shattered (been there, done that).
AndyMark? http://www.andymark.com/product-p/am-2324.htm |
We've used a fair amount of smoked PC from mcmaster and it isn't that great of a look (especially for the price increase). We have found that spraying the underside of clear PC with black or a team color looks much better. It maintains a nice glossy finish this way.
Cheers, Bryan |
#11
Some hobby stores do offer translucent black tint paint. I have also wondered about using window tint. Has anyone tried that?
#12
On the window tint subject, I'm fairly sure that the right tint (probably around 35%) would do the trick. The only concern here is the heat used during application, since it could - in theory - warp the polycarb panel if the applier wasn't careful. |
#13
Many "quick" and "diy" window tints are applied cold. They are lousy for durability on cars, but should last quite a while on a bot can get them at walmart anf similar.
Be careful with tints that may have metallic components, as they can block EM waves (like theradio signal). |
#14
The spray on works well just make sure you have a steady hand...its a rattle can and will end up streaky/runny if your not careful. The window tint works great on flat lexan that isn't expected to flex. It'll crack the tint on a flexing piece. ![]() |
#15
All the plastic you could ever want Boedeker Plastics
Tell them you are on a high school robotics team and they will give you a discount. Highly recommended service, almost like Andy has a Texas brother.... |
