Someone managed to set the default front view to be slightly offset from true Othographic, and it is messing everything else up! For some reason, the reset to defaults, reset front etc. options only reset to the current view.
Is there a way to lock a view on to an object or work plane? Please see attached image for an example of the issue. Note that the view cube is set to a straight side, while the CAD is offset. |
