Go to Post A clean pit is a happy pit, a clean pit is a controlled pit, a clean pit is a safe pit. - DjAlamose [more]
Unread 01-23-2014, 04:38 PM
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Frame Perimeter Tolerance
Let me start by saying I did search first so I know there is another thread here with a similar topic however since that thread was started prior to the new sizing rules I thought it would be better to just start a new one. My question is what is the tolerance on the frame perimeter at inspection? My team is making our frame 28"x28" - which is the max frame perimeter (we did it last year with no problem so that is not our concern). What we were wondering is if we were to powdercoat the frame, thus adding a few thousandths of an inch to each side, would that be a problem? I wouldn't think it would be but I wanted to see if any other teams had experience with this. Thanks,
Jesse
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 01-23-2014, 04:44 PM
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Frame Perimeter Tolerance
Why would you build to the nominal max limit?
Mentor 2415
Unread 01-23-2014, 04:46 PM
BigJ BigJ is online now
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Well, in my experience, the inspector won't pull out a giant 30" caliper to measure your perimeter, but I'd caution against building to the very max. I'd leave at least a quarter-inch, if you still have the chance.
Unread 01-23-2014, 04:47 PM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
28" inches is 28" regardless of whats on it, however they do say things that protrude out like nut ans bolts < than 1/4" are ok so I would bet it would be ok, but thats just my bet. I would think that if you asked they would say what I said in my first sentence.
I dont think they measure to the nearest 1/16 - .0625, and I cant imagine your coat being much ticker than that? Ifs its an 1/8 thats a different story. Depend on the inspector.
Last year we used 1/4 coper tube from our compressor because of heat. We were failed even though it was not in the rules. Another team got inspected with coper and passed. We brought this to their attention and they revoked the other teams inspection cert and made them change it.(we felt bad) My point is ruels are interperted differently by different inspectors.
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
Rookie Year: 1997
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
If the inspection procedure is the same as last year, the inspector will be using a tailor-style measuring tape to check the frame perimeter. They will wrap it around the frame in the bumper zone across features that would define a "frame perimeter" per the rules (see the diagrams about gaps, etc). If that end tab is past the 112" mark, you're no good. So, it's up to you to decide the tolerance of the tape, but I'd say it is well under 1/16".
Regarding your powdercoat, that will be more than just a couple thousandths in thickness. I would put it into the tens of thousandths overall. So, if you gain 0.020 (0.005 per side), you're approaching the point where an inspector's tape will reflect the difference.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 01-23-2014, 04:50 PM
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
All I can really say is good luck. Building up right against the limit in itself is asking for a bad time.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 01-23-2014, 04:51 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
This procedure is not consistent across events. We were never inspected this way.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 01-23-2014, 04:53 PM
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
No margin? If you design something to be 28 inches square, there's a 50-50 chance it will be under and a 50-50 chance it will be over after fabrication. If the inspectors see a lot of robots close to the limit they may improve their measurement accuracy, in which case, even a 1/64 inch overage will be out of limits. The rules give no tolerance on the limit.
FRC #6357
Rookie Year: 1997
Must be a Texas thing then. Lubbock, San Antonio, and Houston used the tailor's measuring tape to check the frame perimeter.
I stand corrected.
FLL Mentor 2006
FRC 619 Mentor 2002
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
There is no tolerance on the frame perimeter measurement. It is either 112.0 inches or less, or it is out of compliance with the rules.
Unread 01-23-2014, 04:54 PM
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Please, please, please DO NOT BUILD YOUR FRAME 28 x 28!!!!
Let's assume you get your robot together perfectly, with absolutely no extra width or length, you pass your inspection, and play all your matches. Then, you go to pass inspection, and you robot is suddenly 112.5" in frame perimeter. How? When you got the corner of your frame smushed in because you drove into a wall and were hit by another robot, the frame perimeter changed, and you got too big. It's happened to us before, and the last thing an inspector wants to tell you is that your frame is 0.5" too big, and the last thing you want to do is make your frame smaller. It's really, really hard. Trust me....
Unread 01-23-2014, 05:00 PM
AKA: Jesse Gibson
Team Role: CAD
Rookie Year: 2011
Thank you all for the input, most likely will not be powdercoating the frame then. As far as the frame perimeter goes, it's a little late to change now (parts already out for mfg) but we should be fine - last year we built to 28x28 doing our entire frame by hand, this year we are doing sheet metal (lasered and bent), so theoretically much tighter tolerance there. I will keep that advice in mind in the future though.
2011 - Logomotion
Unread 01-23-2014, 05:11 PM
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
[quote=amesmich;1331369]28" inches is 28" regardless of whats on it, however they do say things that protrude out like nut ans bolts < than 1/4" are ok so I would bet it would be ok, but thats just my bet. I would think that if you asked they would say what I said in my first sentence.
/QUOTE]
In regards to this, previously, I've had the "issue"(ie. it wasn't really an issue) where the LRI further clarified that that rule is simply there in respect to your own FP-ie. if you're 27.5x27.5, those protrusions are okay, but if you're 28x28, they would NOT be okay, because (as said in other posts) 112 inches is 112 inches, so no matter what you still need to fit under the 112 inches-including protrusions.
Keep in mind, this was just one LRI's interpretation, but I assume it'd be fairly consistent across the board.
Unread 01-23-2014, 05:26 PM
AKA: Jesse Gibson
Team Role: CAD
Rookie Year: 2011
That's an interesting interpretation of the rules. R2 says that minor protrusions (such as bolt heads) less than 1/4" are not considered part of the frame perimeter doesn't mention anything about those allowances being related to the rest of the perimeter. I guess in certain situations the lead robot inspector just has to make a call but that would be a situation when I would definitely want to have a copy of the rules on hand.
2011 - Logomotion
  #15   Spotlight this post!
Unread 01-23-2014, 05:29 PM
magnets's Avatar
Rookie Year: 2012
[quote=DevenStonow;1331383]
/QUOTE]
Well, that inspector is wrong. The rule says "Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME PERIMETER." It's very clear.
