Go to Post FIRST continues their full-frontal assault on mentor's vacation days. - Lil' Lavery [more]
Unread 23-01-2014, 17:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Frame Perimeter Tolerance
The recommendation from experienced (OK Old) mentors is to build to 1/4" under in every dimension. Tolerances in bending are finite and they could be too big. Whatever way the Inspection team decides to measure the Frame Perimeter, it better be less than 112". The guideline is using a 112" string wrapped around the robot frame. Boltheads, welds minor protrusions are different than a misplaced bend, angle stock in the corner or a transmission that stick outs from the frame. We call this practice "playing with fire".
Al
WB9UVJ
www.wildstang.org
________________________
Unread 23-01-2014, 18:00
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
I hope it never comes to this, but remember that the pits (especially the ones at Championship) can be rather toasty. Aluminum expands 12.3E-6 inches for every extra degree Fahrenheit. If your build space is rather cold like ours is (~60° F), and the pits are ~76° F, a 28x28 inch robot could gain 0.0220416 inches in its perimeter. That could cause you to fail inspection. Build smaller on purpose!
(The calculations in this post are intended as a thought exercise and are not intended to be scientific.)
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 23-01-2014, 20:07
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
[quote=DevenStonow;1331383]
Originally Posted by amesmich View Post
28" inches is 28" regardless of whats on it, however they do say things that protrude out like nut ans bolts < than 1/4" are ok so I would bet it would be ok, but thats just my bet. I would think that if you asked they would say what I said in my first sentence.
/QUOTE]
In regards to this, previously, I've had the "issue"(ie. it wasn't really an issue) where the LRI further clarified that that rule is simply there in respect to your own FP-ie. if you're 27.5x27.5, those protrusions are okay, but if you're 28x28, they would NOT be okay, because (as said in other posts) 112 inches is 112 inches, so no matter what you still need to fit under the 112 inches-including protrusions.
Keep in mind, this was just one LRI's interpretation, but I assume it'd be fairly consistent across the board.
Was this issue when they still had the sizing box and the size limit of 28"x38"? Because back then that was the correct interpretation.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-01-2014, 21:35
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
[quote=kevin.li.rit;1331449]
Yes, this was 2012. So yeah, maybe since then that is a different interpretation (I didn't read into the exact wordings in the past manuals)
