Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 23-01-2014, 17:54
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
CANNOT DEPLOY CODE
Hello - I am the head programmer from the LF robotics team. I am trying to deploy some code that did work about a week ago - I added in some motors and was attempting to deploy the code again - no errors came up - I went to the driver station and everything was green and good-to-go - I enabled teleop and nothing happened - IP's are good - subnet mask is correct for deploying and running code - firewall is disabled - netbeans team number is set - the image is good on the cRIO - I checked everything I could think of and the problem still occurs.
Does anyone happen to know what I could do to fix this issue?
THANKS!
