Go to Post Isn't that the name of the game... Roomba Rumble? - Mr. Van [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #16   Spotlight this post!
Unread 24-01-2014, 14:41
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: 5" wheels
Try skyway wheels. (Remember them?) They used to be in the KoP and they sell a 5inch wheel.
http://www.skywaywheels.com/products_004.htm
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #17   Spotlight this post!
Unread 24-01-2014, 14:49
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Unlike many here...
I highly recommend banebots wheels for drivetrains.
They come in 4 7/8 diameters. They have crazy high traction. They do wear more quickly because of this though, so it is usually wise to get a spare set of you go this route. Get some blue wheels for testing, orange or blue for competition.
  #18   Spotlight this post!
Unread 24-01-2014, 15:13
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Re: 5" wheels
Ahh, the infamous Skyway wheels.
Great find!
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
  #19   Spotlight this post!
Unread 24-01-2014, 16:06
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: 5" wheels
If you do opt to go with Banebots wheels for the drive, I'd suggest going with one set of 3.875" wheels to be used on one end rather than a 4.875" to be used as the center wheel. You'll still end up with only four wheels in full contact with the carpet under normal conditions (a "pivot" as you called it), thus achieving the shortened wheelbase and improved turning. However, you'll have a much less significant difference in surface speed of the wheels (a larger diameter wheel spinning at the same rate as a smaller diameter wheel will have a faster linear velocity at the edge of the wheel). Especially if you mount the banebots wheels on the lighter end of the robot, so under nominal conditions they won't be contacting the floor (thus your four wheels with identical diamters will be in contact). You want to avoid differening surface speeds when possible, so you can harness the static friction of your treads rather than the lower dynamic friction.
  #20   Spotlight this post!
Unread 24-01-2014, 23:13
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: 5" wheels
Originally Posted by Gregor View Post
Raise one of the outside wheels 1/8". Drill a clearance hole in the current existing holes for your outside wheels, then rivet or bolt a new piece of metal overtop, which the axle hole raised.
I know 610 did this last year, ask them for a few pictures.
Similar to this^
Drill the hold 1/8" higher. Insert "shims" under axle. The shims we have used were steel sheet metal.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
  #21   Spotlight this post!
Unread 25-01-2014, 08:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Re: 5" wheels
If you have bolts as axles, (not live axles) you could re-drill the 3/8" holes with 1/2"(offset higher 1/8") and change wheel bearings to 1/2".
Or check a few 4" wheel brands, like the vex or Andymark traction and see if they are slightly bigger or smaller.
  #22   Spotlight this post!
Unread 31-01-2014, 21:17
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Thanks for the help everybody. We got it working by using aluminum plates riveted to the chassis as Gregor suggested. It works like a charm now
