Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Unread 23-01-2014, 21:06
MHSrobotics2853's Avatar
MHSrobotics2853 MHSrobotics2853 is offline
Mililani Robotics
FRC #2853 (Trobobots)
MHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really nice
Microswitch only returns 0
We need help with our microswitch.
We've tested it with the multimeter (returns 5V when not pressed 0V pressed). When we press it, it won't return 1, the only value it returns is 0.
It's plugged into the Digital I/O port (we've already swapped out three sidecars so we know that that's not the issue). Our code is as follows:
Code:
#include "WPILib.h"
#include <DigitalInput.h>
#include <DigitalOutput.h>
#include <DigitalSource.h>
class RobotDemo : public SimpleRobot
	DigitalInput micro;
public:
	RobotDemo(void):
		micro(2,14)
	void Autonomous()
	void OperatorControl()
		while (IsOperatorControl())
			DriverStationLCD *groundhogs = DriverStationLCD::GetInstance();
			while (micro.Get() == 0)
				groundhogs -> PrintfLine(DriverStationLCD::kUser_Line2, "I'm not pressed!");
				Wait (0.005);
				groundhogs -> UpdateLCD();
			groundhogs -> PrintfLine(DriverStationLCD::kUser_Line2, "I'm pressed!");
			Wait (0.005);
	 * Runs during test mode
	void Test() {
START_ROBOT_CLASS(RobotDemo);
We've been ripping out our hair over this for two days already. Any suggestions/answers/holy revelations? Thanks!
Unread 23-01-2014, 21:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Microswitch only returns 0
You're instantiating the switch on digital module 2, which is probably not what you want.
Unread 23-01-2014, 21:13
Mililani Robotics
We've already tried it as (14) and (1,14). (2,14) was our most recent trial. Still won't work
Unread 23-01-2014, 21:26
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
1. How exactly do you have it wired?
2. Try changing the cable that connects the sidecar to the cRIO
3. Does it work on another port?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 24-01-2014, 00:09
Mililani Robotics
1. Digital module to sidecar (occupies second slot on the cRIO), sidecar to switch on the Digital IO row
2. We have already switched but it still hasn't worked
3. No, not on any port (we've literally tried all of them)
Unread 24-01-2014, 00:20
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
how is your limit switch wired?
The digital sidecar has internal pullup resistors on its input channels. This means that when nothing is connected to the pins it sees 5v.
Your switch should have a ground and a signal wire connected to it (5v isnt' required). Per your stated wiring, when the switch is pressed, the signal wire should be shorted to ground. If this is not the case, then you won't see a logic level state change at the digital side car.
http://team2168.org
Unread 24-01-2014, 00:23
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
In this case I would expect it tor return a 0 when pressed. Does it return 1 when not pressed?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-01-2014, 00:35
Mililani Robotics
It doesn't it only returns zero
Unread 24-01-2014, 00:38
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Can you post a wiring diagram of how your switch is wired?
Kevin Li
596 - Sciclones
Unread 24-01-2014, 01:01
Mililani Robotics
Its our test bed; the microswitch is in the lower right connected to the Digital IO slot in the sidecar, which is connected to the second cRIO module slot.
(Ignore bunch of arrows coming out of the sidecar, mocked this up real quick.)
Unread 24-01-2014, 01:22
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You're only showing one connection for your switch, and its ends aren't labeled with anything specific. People keep asking you how you have it wired, and obviously you aren't understanding the level of detail they're looking for. What pins on the Digital Sidecar connect to what terminals on the switch?
