Go to Post The purpose of this forum is for us to communicate our ideas, so that we can collectively strengthen our ability to inspire others. - Jaine Perotti [more]
Unread 24-01-2014, 00:28
bharrison6 bharrison6 is offline
FRC #3843
bharrison6 is on a distinguished road
Closed Loop Pneumatics
Was wondering if you did the setup with the compressor and regulator off the robot and filled your tank with 60 psi through the off-board regulator and had the cylinders extended. You then disconnect the off-board compressor/regulator and just have your tank, 120 psi relief valve and cylinders. You then retract the cylinders through mechanical means which effectively decreases your total volume and increases your total pressure. There is no pressure gauge to read this increase in pressure but I am thinking it might break the "working" pressure rule. But maybe not?
If yall think it does then does it fall in the category of "closed" loop Pneumatics which do not have psi limits?
Thanks for the replies.
Unread 24-01-2014, 00:31
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Closed Loop Pneumatics
I think because you are intentionally making your 60psi system go over 60 psi by applying a force, you are breaking pneumatic rules.
Unread 24-01-2014, 00:50
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Instead of "I think", how about taking a look at Q&A 129, and making that "I know"? (Yes, you are correct--it's just that "I think" doesn't fly at inspection.)
You're also going to be in violation of R79. Oh, and yes, you DO have a gauge to read it, per R86. 3 potential rules violations, one setup. I'd almost think this was bumpers back in '09...
And no, it's not a closed-loop pneumatic system. For the record, those don't exist in FRC. You CAN use COTS closed-loop gas shocks--those don't count as pneumatics--but the described system is 100% pneumatic, and generally speaking you'd have a hard time getting it to be COTS, with you filling from an offboard compressor, so don't try that approach.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 24-01-2014, 01:34
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
just move the regulator to the robot. it by itself doesn't weigh much.
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 24-01-2014, 09:20
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
And you can effectively double the volume of your tanks by storing high pressure air, which is worth its weight in gold.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
