Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
  #16   Spotlight this post!
Unread 27-01-2014, 17:21
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: Shifting with servos
Originally Posted by yash101 View Post
Actually, FIRST goes by the output power, not the input power.
Servos are a very bad choice because you will be shifting at top speeds.
You just need to have a pneumatic tank, valve, solenoid, all the basic components. You may be able to run off an external compressor, and precharge the cylinders!
Servo's aren't a very bad choice. They're a great solution if you're only looking to shift a few times a match while you're not moving.
Servos have very little output torque, as compared to a piston.
This is false, as pneumatic cylinders have no torque. You can also gear up your servo or use an alternate motor.
Also, designing the system with pneumatic pistons would be very easy!
Yes, but a servo is easier. The super shifter comes by default with a servo. You'd need to spend more money and assemble an extra cylinder mount. Also, you'd have to put tanks, valves, regulator... on the robot. I'd argue that servos are a lot easier.
  #17   Spotlight this post!
Unread 27-01-2014, 18:47
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Originally Posted by MichaelBick View Post
Some teams don't like using pneumatics because of the weight. If you are just running shifters than it may not be worth it.
67 has been one of these teams in the past. They have used the window motors instead of servos to successfully shift. You cannot shift on the fly, but it can also be lighter than a pneumatics system.
Or because they haven't got anyone with experience using them. 67 has not used pneumatics since 2004 from what my brother was saying.
Bear in mind that when you are disengaging the dog gear you are fighting friction. If you don't have something else taking the load from the winch you will be fighting a LOT of friction. You can overcome it but chances are it won't be easy. A simpler solution might be to use a ratchet style system that takes the load. You'd need to figure out the math behind your particular system to tell if a servo or a motor with a cam could achieve the desired results.
  #18   Spotlight this post!
Unread 28-01-2014, 21:40
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
Rookie Year: 2013
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
I hope you are geared pretty low, considering the tension levels needed to launch the ball well. A ratcheting mechanism of some type will also be needed to avoid stalling the motor. Is using electrical solenoids an option for shifting?
  #19   Spotlight this post!
Unread 28-01-2014, 21:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
When would anyone ever want to do that?
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #20   Spotlight this post!
Unread 29-01-2014, 08:35
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Well, one would hope the catapult winch isn't driving while you shift into neutral.
As to the original question, I have two points to consider:
1. Using a ratchet to take the load off of the gearbox entirely is a good idea. We built a custom dog system for a winch, and once we get it into place the motor drives back a little and the ratchet/pawl takes the entirety of the load, so we can use a tiny little pneumatic cylinder to disengage the winch. (We have a fatter-but-not-insanely-so cylinder then disengaging the pawl, which takes about 12 lbs of force.) Given that you probably need a ratchet of some kind to keep the system from back driving anyway, this is a good idea to consider.
2. If you're not going to have any other pneumatics on your robot and a servo just won't do, consider using a screw drive. They're as strong/fast as you need them to be (based on motor power, of course--in 2010 we lifted our robot using a CIM-driven screw), accurate, easy to control, and for your application perhaps the best thing is that they're motor driven.
What they're not is efficient, but you can use this to your advantage to prevent back drive in some applications where that's desired.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #21   Spotlight this post!
Unread 29-01-2014, 10:39
FRC #0079
Rookie Year: 2000
Heavily depends on your strategy. Shift on the fly is nice but if your ratios are spread too wide it can actually be jarring. Perhaps the game has multiple modes wherein one speed is beneficial and another wherein a vastly different speed is useful. OR in the case of a power takeoff.
I've also run bots that servo shifted dewalts and when a shift was requested we backed off the power to the drive motors momentarily while the shift happened. Not the best, but it worked.
Course, I'm loving the simplicity of a 6CIM single speed right now.
