Go to Post We appreciate the time/effort of everyone who contributes to Chief Delphi... hopefully, someday soon we'll be experienced/seasoned enough to contribute advice ourselves... - Michael Blake [more]
Unread 24-01-2014, 18:20
sahilrarora sahilrarora is offline
FRC #4188
sahilrarora is an unknown quantity at this point
Powering solenoids
Would it be legal to connect/wire two solenoids to one digital input if we were using two solenoids at the same time?
Thanks!
Unread 24-01-2014, 18:27
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Powering solenoids
Yes it would be but what would be the point of wiring your solenoid to a digital Input?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-01-2014, 18:31
Imaginary Friend
AKA: Kevin Li
Team Role: Student
If you were asking if you can wire 2 solenoid valves to one output of the solenoid breakout, the answer is no per r51.
<R51> Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device may control one and only one electrical load.
Kevin Li
596 - Sciclones
Unread 24-01-2014, 18:41
FRC #4188
Would it necessarily be an electrical load? It's just a signal with an insignificant power use.
Unread 24-01-2014, 18:55
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Hmm, I wouldn't classify it as a signal since the output is directly driving the solenoid.
However, the solenoid breakout is not listed as a power regulating device under r50. But multiple devices per output isn't explicit in r51.
As I read it now it would be okay.
Can someone else provide clarification or does this need to go to the Q&A?
Kevin Li
596 - Sciclones
Unread 24-01-2014, 19:18
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
After the chart in R51, it says:
*Multiple low-load, pneumatic solenoid valves, electric solenoids or CUSTOM CIRCUITS may be connected to a single relay module. This would allow one (1) relay module to drive multiple pneumatic actions or multiple CUSTOM CIRCUITS. No other electrical load can be connected to a relay module used in this manner.
So as I see it, you can use multiple solenoids on one Spike relay, but the asterisk is not included on the solenoid breakout.
So if it is a 12v solenoid you are okay, if it is 24v you are out of luck.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 24-01-2014, 19:22
Imaginary Friend
AKA: Kevin Li
Team Role: Student
But R51 only prohibits connecting more than one device to the output of a power regulating device from r50, the solenoid breakout is not included in r50.
Kevin Li
596 - Sciclones
Unread 24-01-2014, 19:56
Team Role: Coach
Rookie Year: 2010
But it is included in the chart found in r51. And also, nowhere does r51 reference r50. R51 only points to table 4-4, which is listed within r51.
Andrew Basse
Unread 24-01-2014, 22:10
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Except when it mentions power regulating devices for actuators which a pneumatic solenoid does not seem to fall under the category of actuator, only electrical load. So for the OP, I changed my mind again. I would go with no and ask Q&A.
Kevin Li
596 - Sciclones
Unread 24-01-2014, 23:52
zsm150's Avatar
zsm150 zsm150 is offline
AKA: Zack Moore
FRC #0314 (Big Moe)
zsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to behold
Are these two solenoids for a similar use? You could just use T fittings to split the tubing to run multiple cylinders off of one valve
Frog Force Team 503 Drive Team 2013-2015
http://www.frogforce503.org/
Big Moe Team 314 Drive Coach 2016-?
http://www.bigmo314.com/
