Go to Post If an alternate is used, all four teams are equal members of the alliance. (Trophies, trips, bling, book tours, custody of the children etc.) - Btower [more]
Unread 25-01-2014, 10:49
[martinskot] [martinskot] is offline
2013 Driver
FRC #4618 (CN Robotics)
Rookie Year: 2013
[martinskot] is an unknown quantity at this point
Solenoid Programming Errors
Hi CD,
This is my first year programming, and 4618's first year using pneumatics. I've programmed according to the WPIlib screensteps and I keep getting an error every time I save and build the program.
Here's what I've done(copied from sections of the program):
DoubleSolenoid *m_leftShifter;
m_leftShifter = new DoubleSolenoid(LEFT_DRIVE_LOW,LEFT_DRIVE_HIGH);
m_leftShifter.set(DoubleSolenoid.Value.kForward);
If someone could tell me what I'm doing wrong or how to fix this it would really be appreciated. If it helps, programming it as a Solenoid instead of DoubleSolenoid and using m_leftShifter.set(true); did not get rid of the problem.
EDIT: I could set a motor value successfully, just not the solenoids.
Thanks
Unread 25-01-2014, 16:54
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Solenoid Programming Errors
The code in the WPI documentation tends to be for Java, not C++, and it looks like that's what you've written here. (At least on the third line.)
Notice that m_leftShifter is of type DoubleSolenoid*. That means it's a pointer to a DoubleSolenoid object, and so to access methods of that object (like Set()) you need to use the arrow operator (->).
Try this code instead:
Code:
m_leftShifter->Set(DoubleSolenoid::kForward);
Unread 25-01-2014, 21:01
2013 Driver
Rookie Year: 2013
That works! Thanks a ton (metric,of course).
