Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 01-25-2014, 11:03 AM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
WPILib projects don't have standard Java classes?
Hey all,
Been doing some programming lately, wanted to use a .properties file to hold sensor/motor channels. Unfortunately, it appears that the WPILib libraries doesn't have the java.util.Properties class. In fact, that package is missing a *lot* of the standard Java classes.
I checked in the project settings (using Netbeans 7.4), and it says I'm using JDK 1.7, so the classes should be there.
Any advice?
Unread 01-25-2014, 12:17 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: WPILib projects don't have standard Java classes?
The cRIO runs the Squawk JVM, which is based on Java ME (a subset of Java 1.3). There are lots of things that aren't implemented in newer versions of Java that aren't in squawk. The project properties in netbeans don't mean anything, since it uses the ant buildscripts provided with the FIRST sdk.
There are some classes that aren't required by Java ME, that squawk implements anyway. These are in com.sun.squawk.util, but properties aren't one of them. What did you want to use properties for?
The 2015 control system will use Java SE Embedded. It won't be nearly as stripped down as Squawk.
Unread 01-25-2014, 02:33 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
If you are looking into using a properties file to avoid having to recompile/deploy every time you want to tweak a setting, I would suggest taking a look at 254's Constant implementation from 2013.
ConstantBase
Constants
It's a pretty straight forward implementation. Default values for all variables are stored in the Constants class. When an instance of this class is created (from robotInit() would be a good idea), it will go out and look for a file called Constants.txt. It will read in the key value pairs defined in the txt file. For each key/value pair in the file, it will search the list of known keys for a match. If it finds a matching key, it will overwrite the value specified.
Your Constants.txt file only needs to define values for keys you would like to override the default of.
I integrated the ConstantBase class into my team's code last night, haven't had a chance to deploy the code yet, but we will likely use this on our 2014 robot.
http://team2168.org
