Go to Post its pretty great when non FIRST friends go into your purse for chapstick or something and find a spike... - anna~marie [more]
Unread 25-01-2014, 14:48
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
pic: Did Somebody Say Defense Game?
Here's a few specs...
The drive consists of:
12x - 4" VEXPro Traction Wheels in 1.5" wide configuration
2x - VEXPro 3-CIM Ball Shifters with 9.07:1 High Gear and 24:1 Low Gear
22x - 50-tooth VEXPro gears for the wheels and idlers
4x - CIM motors (2 on each gearbox)
2x - MiniCIM motors (1 on each gearbox)
  • Each wheel is combined with a 50-tooth gear via a VEXPro Versa Hub.
  • Two wheels are directly driven via Hex output from the gearboxes.
  • All 6 wheels on each side are driven via connecting 50-tooth idler gears (not shown in this picture) in a 1:1 ratio.
  • The wheels are aligned on a 32' arc, allowing for easy turning with minimal scrub.
Unread 25-01-2014, 14:49
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Re: pic: Did Somebody Say Defense Game?
Cross your fingers that it will turn without popping the breakers.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 25-01-2014, 14:53
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Actually, they're missing a couple of wheels. (2007 joke)
If it's anything like what they've done before, the wheels are in a bit of an arc, so it acts more like a 6WD drop than a 4WD "bounce turn".
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 25-01-2014, 14:58
Andrew Lawrence
Posts: n/a
Looks like it'd be more of an 8WD, but I could be wrong.
Unread 25-01-2014, 15:05
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
I agree, looks like they are set in pairs.
If I were holding the joysticks in this case :
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 25-01-2014, 15:49
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Is this a similar design to what your team ran in 2008? If so, what reliability changes were made?
2008 robot
Context (Still one of the classiest decisions in FIRST history)
Queen's Applied Science '13, Applied Mathematics
Unread 25-01-2014, 15:03
Chris is me's Avatar
AKA: Pinecone
I don't see this as having much higher turning scrub than a six wheel drive. In theory, this system would behave like a tread drive and this would turn even without drop. I guess we shall see!
Unread 25-01-2014, 16:23
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Rookie Year: 2007
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Originally Posted by cbale2000 View Post
Yes. Can you sent a video with it running
Unread 25-01-2014, 16:28
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Oh god. it's back.
My comments do not reflect the views of associated teams.
Unread 25-01-2014, 16:57
Mgjohnson's Avatar
Mgjohnson Mgjohnson is offline
AKA: Grace Johnson
FRC #2481 (Roboteers)
Mgjohnson is an unknown quantity at this point
Hey! That's almost as many wheels as ours.
Unread 25-01-2014, 17:08
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Adding wheels doesn't really increase your traction/pushing power, does it? I'm sure that the extra width helps, but not the number.
Unread 25-01-2014, 17:27
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Adding surface area in contact with the ground (up to a point) increases traction. It doesn't matter if it's through wider wheels, or more wheels. If friction worked just the way the coefficient of friction says it will, then neither width nor number of wheels will affect traction at all. You could have three 0.1" thick wheels, and have the same amount traction, but friction doesn't follow the super simple columbic prediction, especially on carpet.
Unread 25-01-2014, 17:42
FF TSL: Frog Farce
Yeah, I doubt that all of those wheels are on the ground at the same time though, unless they don't want to turn.
Unread 25-01-2014, 18:23
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
How long are you going to have in a pushing match with a 6 cim drive before you start popping breakers?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
  #15   Spotlight this post!
Unread 25-01-2014, 18:39
Deke's Avatar
Deke Deke is offline
no team (No Team)
Rookie Year: 2013
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Love it!
