Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 25-01-2014, 16:39
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Get Array From SmartDashboard
I'm trying to get an array of information about the vision targets to send from the SmartDashboard to the cRIO. I absolutely can't figure out how to do this - the documentation seems much too sparse.
I know that when using LabVIEW we could just use a "SD Get Numeric Array" or something like that. Where's the equivalent function in C++ (or how do I work around it for myself?)
Unread 29-01-2014, 07:26
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Get Array From SmartDashboard
Quick question... are you trying to write code that runs in a SmartDashboard custom widget that creates the array of values and sends them to the robot program?
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 29-01-2014, 11:05
AKA: Brad
Here is some documentation that shows how to retrieve values in an array on the robot that were generated by RoboRealm for doing vision operations.
http://wpilib.screenstepslive.com/s/...with-roborealm
and here is some documentation that shows how you might send values from a Java client program running on the desktop.
http://wpilib.screenstepslive.com/s/...client-pc-side
This desktop example doesn't use arrays, but from the previous example, it might give you enough information to make it work.
Hope this helps.
Brad Miller
Unread 29-01-2014, 11:17
bvisness's Avatar
Rookie Year: 2010
Thanks for the advice. Since I'm using C++ (which makes arrays a giant headache) I actually ended up using VBScript in RoboRealm to save the array data I wanted into single variables for sending to the robot. Seems to be working fine!
