Go to Post There's more to the game then winning. - Gabriel [more]
  #16   Spotlight this post!
Unread 25-01-2014, 22:30
Andrew Lawrence
Posts: n/a
Re: 9 mm Wide Belts
Originally Posted by sdcantrell56 View Post
Or the belts are outside of their safe working limit. They were 26 teeth, and slightly on the overtight side. In my experience, belts are not very well suited for rapid direction changes with relatively high torque and minimal tooth engagement which is what happens in a west coast drive since pullies are generally kept smaller than 2" diameter.
That's very interesting. I've never heard of problems on correctly tensioned belts in a drive. Were you using GT2? HTD is better rated for rapid direction change, though it really shouldn't matter.
  #17   Spotlight this post!
Unread 25-01-2014, 22:39
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: 9 mm Wide Belts
GT2. I know of plenty of teams experiencing ratcheting with 9mm wide belt. Once you go up to 15mm ratcheting only happens in extreme cases, but then you're much wider than running #25 chain
Mentor 2415
  #18   Spotlight this post!
Unread 25-01-2014, 23:06
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Re: 9 mm Wide Belts
We ran 9mm wide GT2 belts last year, and didn't have any ratcheting. We had some wear, but it was what you would expect for a device running outside the rated specifications. 1 set of belts lasted the entire season (2 competitions, 1 offseason, and lots of practice.) Ratcheting occurs when your belts are under-tensioned, which means that your belts were under tensioned. You can look at the failed belt to figure out what was wrong. For comparison, we had a 24 tooth pulley with a 3.5" diameter wheel.
  #19   Spotlight this post!
Unread 27-01-2014, 13:28
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Re: 9 mm Wide Belts
What pullies are you running, specifically tooth count? Also will you have a means for tensioning or are you setting it up for exact center to center distance?
We're using the small 18 tooth pulleys (9 teeth in contact). We will have the means to tension the belts.
I suppose that in the worst case scenario, we'll switch back to 25 chain. Now were are we going to get the weight for that...?
- Mr. Van
Coach, Robodox
  #20   Spotlight this post!
Unread 27-01-2014, 13:36
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: 9 mm Wide Belts
We experienced ratcheting problems with 9mm belts. Our experience mirrors Sean's. We now use 15mm belts and 24T pulleys for our 6 CIM WCD.
I would be very hesitant to take risks with belt sizing, unless you have a good reason. Looking pretty is not.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
  #21   Spotlight this post!
Unread 27-01-2014, 13:50
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: 9 mm Wide Belts
- Mr. Van
Coach, Robodox
This will likely be an issue.
  #22   Spotlight this post!
Unread 27-01-2014, 14:28
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: 9 mm Wide Belts
Worth taking a look at this document Adam threw together. Lots of great input from tons of teams on their experience incorporating belts into their custom drivetrains. We referred to this when throwing our off-season WCD belt drive together.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #23   Spotlight this post!
Unread 27-01-2014, 15:45
#0599 (Robo-Dox)
Re: 9 mm Wide Belts
Thanks Mike and Adam! Very good information (if not entirely encouraging) - better know now than later!
- Mr. Van
Coach, Robodox
  #24   Spotlight this post!
Unread 27-01-2014, 17:18
Mason987 Mason987 is offline
President
FRC #0987 (High Rollers)
Team Role: CAD
Rookie Year: 2012
Mason987 is an unknown quantity at this point
Re: 9 mm Wide Belts
We've used 9mm HTD belts for the last 8 years no problem. GT2 might give you a few problems. Small pulleys will do the same. I believe we run 36t pulleys for all of our wheels. We've used them for our standard 6" wheels, and 8" wheels as well. HTD is better for the quick change in direction. HTD is High Torque Drive.
Try using SDP-SI's belt distance calculator. It'll give you pretty good numbers to run with. We also pull all of our pulley files from SDP-SI for our CAD.
http://www.sdp-si.com/cd/default.htm
  #25   Spotlight this post!
Unread 27-01-2014, 17:24
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: 9 mm Wide Belts
For avoiding belt slippage, HTD is the way to go. I've had mixed experience running 9mm. A long time ago, we made our own pulleys (around 20t) out of aluminum, and we had the center to center distance very accurate, and it worked very well. Later, using an off the shelf pulley and a not as super rigid frame with a not super accurate (but still within 0.002") center to center, we experience some slip.
I'd go with the 15mm if possible. If you can't, you'll survive with 9mm, but you could have some slipping. Slipping isn't that bad (apart from belt wear).
  #26   Spotlight this post!
Unread 27-01-2014, 21:04
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Team Role: Mechanical
Rookie Year: 2010
Rynocorn is on a distinguished road
Re: 9 mm Wide Belts
Thanks for all the advice. We will be running a 6 Cim drive train (maybe shifting if VEX gets them in stock) with 8WD and it would be 9mm HTD belts from VEX with their 42 tooth versa pulleys. All 4 wheels would be powered on either side. Also, when I said it makes the CAD pretty, all I meant was that it would make my life easier my not having to change all of my mounting plates .
What about having one 15mm belt on the inside part but then 2 9 mm belts on the outside? We might try that to save some space but still have the advantages of 15mm wide pulley on the 4 dropped drive wheels.
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
