Go to Post 27 ft/s? They must really "Rush" around the field - Michael Corsetto [more]
Unread 01-25-2014, 10:13 PM
Thorn Thorn is offline
None #2869 (Regal Eagles)
Team Role: Teacher
Rookie Year: 2012
Thorn is an unknown quantity at this point
Connecting two toughbox minis together
We need to use a very high gear ratio to generate enough torque to pull back a sling shot. Can we take the output of one gear box and connect it to another gear box where the motor connects? I think that should multiply the gear ratios together and provide a cleaner design than trying to put together our own gears.
Has anyone done this before? Do you think this can work?
Unread 01-25-2014, 10:20 PM
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Connecting two toughbox minis together
Have you looked at the Stackerbox? It is designed to do just what you describe, and is very compact. Also, there are a few COTS gearboxes that have outputs matching a CIM mount, such as the VersaPlanetary. You could use two bag motors through VersaPlanetaries mounted into your Toughbox Mini to get a lot of reduction with near the power of a single CIM.
-Gary Forbes
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Technically what you are saying is possible, but you are going to have to deal with the output shaft of the first gearbox being different than what the second is built for as an input. It is also going to be a very oddly shaped contraption that you may have a hard time mounting. For high torque with CIMs I recommend the BaneBots P-80 they can get to some crazy high torques in a nice package. (Plus you get $30 off if you use your BaneBots voucher)
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 01-26-2014, 05:51 PM
Team Role: Teacher
Rookie Year: 2012
Thank you for the recommendation!
One gear box is simpler than two and banebots has the high ratios I was looking for. How do I get that $30 discount? Is there some link from the TIMS system? Is there just a coupon code based on my team number?
Unread 01-26-2014, 06:06 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Especially with high ratio gearboxes, make sure the output torque rating of the gearbox is sufficient to withstand the load you plan to drive.
Unread 01-26-2014, 06:40 PM
nathannfm's Avatar
AKA: Nathan
FRC #3940
I don't do ordering for my team so I couldn't tell you exactily but here is the page from them that describes how to do it http://banebots.com/c/FIRST (the qualifing P-80s are at the bottom of the page, I hope one of those ratios works for you)
Unread 01-26-2014, 07:00 PM
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
There will be a code in your TIMS account. Just copy the code and paste it in the Banebots order page. The $30.00 comes off the total immediately.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 01-26-2014, 07:19 PM
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
What motor have you selected and reduction ratio do you need?
Unread 01-26-2014, 07:57 PM
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
+1. The theoretical torque figure you get gearing a CIM 256:1 will shred the internals of the gearbox.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
