Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 00:22
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
A little tip about those drill transmissions and bearings
Posted by Ed Sparks at 2/6/2001 6:42 PM EST
Engineer on team #34, The Rockets, from Bob Jones High / New Century High and DaimlerChrysler.
I was having a little trouble this year with our drill motors heating up and went into a deep trance about what to do about it .....
I discovered a couple things that should have been obvious but for whatever reason, I've always looked around it.
1. I usually disassemble the transmissions 1st thing to remove those pesky backlash pins and to install 6mm set screws to disable the clutch. This time I stripped all of the grease from the parts and assembled them using a silicon based lubricant. You'll be surprised how much "drag" is eliminated and how much cooler your motors will run.
2. So now my brain is stuck on lubricants and I look at those needle bearings I just purchased from Small Parts and popped into our 'bot. Turns out that these babies are packed with a lubricant that is about as thick as tar. I couldn't even spin the bearing with my finger. Once again I stripped the old grease from these bearings and relubed with silicone. Now they actually act as bearings.
I use a product manufactured by "Slick 50" as my lubricant. I also break my transmissions down every now and then to inspect for wear and relube. So if you have a spare transmission lying around, give it a try. If you dont like it, you can always clean it and repack with grease. So far so good......
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
