Go to Post Like fishing, some may get away as you are reeling them in, but never letting out enough line to get the big ones at the bottom is just disappointing. - Eric O [more]
Unread 01-27-2014, 01:52 PM
theonlydvr theonlydvr is offline
FRC #4338
theonlydvr is an unknown quantity at this point
Drawing Circle Over Image Feed Java
Hey all,
We're trying to draw a circle over the location of the ball on the image feed. I have begun work on a camera extension but ran into a problem when trying to get the variables needed (if a circle was found, radius length in pixels, x center, and y center). Is there a way that I can access those values from the SmartDashboard and use them in my extension?
Thanks,
Evan
Unread 01-27-2014, 10:44 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Drawing Circle Over Image Feed Java
(assuming SFX and extending the camera viewer class, which is actually a bad idea that you should NOT DO)
in the registered method (don't forget to call super) snag the datacor eprovider and get the observable values from it (getObservable("path/to/vars")) which will automatically fire if you add change listeners
However, that is a bad idea. You really should create a moving shape control, which ironically is the next turorial we are going to put out so hold tight for a day or two.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
