OPR calculation
Is there a tool/spreadsheet on CD that helps compute OPR based on match results? I'd like to do so for the MN FTC Qualifying regionals. I believe I saw a white paper on the topic before, but I'm having trouble finding it now -- I tried searching.
The difference for FTC is that qualifying matches are 2v2. Thanks. |
Re: OPR calculation
Re: OPR calculation
I'd like to explain the math to the kids (at a high level at least) which I think I can do from what I recall reading about it months ago. (Assume each team always contributes same points toward each match total, then come up with these per team values that best approximate actual match scores.) Then I'd like to calculate it using an 'easy to use' tool. I don't think the kids could start from the underlying math explanation and do it themselves, and they don't really have the time to invest in that excercise (though I may be surprised about that) I have 73 teams, up to 32 matches at each of 5 tournaments-- so ~160 matches of data total. |
Re: OPR calculation
Attached is a simple-to-use tool which accepts data in the following format: RED1 RED2 RED3 BLUE1 BLUE2 BLUE3 RED_SCORE BLUE_SCORE ... and calculates all sorts of stats, including OPR, and outputs the results to a CSV file which can be opened directly in Excel. Tell me what format your data is in and maybe I can make a few simple changes so it can process the whole batch for you. |
Re: OPR calculation
http://www.hightechkids.org/sites/de...%20Results.pdf There are four other similar pages for the other tournaments. I did enter one tournament into Excel with columns: Tourney#, Match #, Color, Score, Team# (total of four rows per match) This format can be easily adjusted, of course. I also just realized I can copy/paste into a text file and get this: Q-1 117-161 B 7972 8034 7661 2887 Q-2 11-82 B 6707 7000 4140 8005 That's: Q-Match# RedScore-BlueScore WinningColor(R/B) Red1 Red2 Blue1 Blue2 It gets a little messed up at page breaks in the PDF but that's trivial to fix. Last edited by jvriezen : 27-01-2014 at 19:28. |
Re: OPR calculation
OPR math:
OPR explained using St Joe event data as example: http://www.chiefdelphi.com/forums/sh...0&postcount=11 "formula" for OPR: http://www.chiefdelphi.com/forums/sh...0&postcount=36 Ed Law's OPR paper http://www.chiefdelphi.com/media/papers/2174 Jay Lundy's OPR & DPR http://www.chiefdelphi.com/forums/sh...&postcount=160 ... I'm sure there are others |
