Go to Post The robot was spinning, I dont have the energy to spin like that. - Joe Menassa [more]
Unread 27-01-2014, 19:30
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
Team Role: Coach
Rookie Year: 2011
pr0ph3t is an unknown quantity at this point
SFX (SmartDashboard 2.0) loading config files
We're trying to use SmartDashboard 2.0 (sfx). So far so good. We've gotten it to load with the DriveStation just fine (although we had to be sure 32bit Java was installed and handling .jar files).
We're having trouble figuring out how to properly load a previously saved configuration (.fxsdash) file. Is the command line option -fx? We've tried adding both of these to the end of the command in "FRC DS Data Storage.ini":
Code:
-fx c:\\test.fxsdash
Code:
-fx:c:\\test.fxsdash
Has anyone figured out how to automatically load .fxsdash files?
