Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 28-01-2014, 19:46
Kuh-Nig-ItsEML Kuh-Nig-ItsEML is offline
FRC #1939
Kuh-Nig-ItsEML is an unknown quantity at this point
RoboRealm to Labview help
I am trying to read the variable BFR_COORDINATES in labview from the roborealm software. Whenever I run the code it fails to read any data. Roborealm itself is producing the data but labview is not receiving the data. The attached photos are of the code in periodic tasks used to access the variable. The data table showing that the data from roborealm(on the DS) is making it to the programming computer. I believe the problem may lie within the call to the variable name but I may be wrong. Any help would be appreciated!
Thanks,
Ethan Lopez
ID:	15997  Click image for larger version
Name:	periodic tasks.jpg
ID:	15998  Click image for larger version
Unread 28-01-2014, 21:10
Re: RoboRealm to Labview help
I'm not familiar with the communication mechanism you are using. I also don't have enough context to know which diagrams are running where. But I'd assume that if you are using RoboRealm, the diagrams are on the cRIO. But you are opening a .2 IP. Does that make sense?
I thought that RoboRealm also implemented Network Tables. That means you should be able to use the LV implementation of Network Tables.
Greg McKaskle
Unread 28-01-2014, 23:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Greg McKaskle View Post
...you are opening a .2 IP...
IP address 10.17.76.2 would belong to team 1776's cRIO. You're on team 1939, aren't you?
Unread 29-01-2014, 08:55
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Rookie Year: 2014
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
We have imaged our robot from last year as team 1776 so that we can run it and our new robot at the same time.
Unread 29-01-2014, 11:22
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
LabVIEW has built-in blocks for reading values off the SmartDashboard and Network Tables. You should just be able to put in an SD Read Numeric Array block and give it the name BFR_COORDINATES. (I forget which palette the blocks are on, sorry.)
