Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 28-01-2014, 22:41
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Legal Pneumatic Fittings - Nipples & Elbows?
R77 of the 2014 game manual states "Pressure transducers, pressure gauges, flow control valves, and connecting fittings" are legal. Can I assume that means any connecting fittings (which are rated for the pressure)?
We're looking to use 1/4" nipples and elbows to connect a tank to a nearby (stationary) cylinder, rather than 0.16" ID tubing for better flow rate. It looks legal to me, (especially as many teams use manifolds and cylinders with 1/4" npt ports).
Unread 28-01-2014, 22:54
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
Rookie Year: 2011
jmartin is on a distinguished road
Re: Legal Pneumatic Fittings - Nipples & Elbows?
Also according to R77 (e), any tubing used has to have an ID of 0.16". So I don't think using 1/4" NPT would be any more useful since you're still limited by the tubing.
Are you sure it isn't ports with 1/4" OD that you're thinking of? Because the 1/8" NPT ports we have fit 1/4" OD tubing. The 1/8" NPT ports have an ID of 1/8". It can be a bit confusing that the 1/8" NPT ports have labels on them saying 1/4.
Unread 29-01-2014, 00:01
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
We've done it in the past with no issue. You can always set it up with the fittings you want and fix it if it is not legal provided it is something you design to be easily changeable
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-01-2014, 01:50
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
That's just it. Elbows and nipples are *not* tubing, so I am thinking that rule doesn't apply. We are planning to use 1/4" (nominal ID) pipe nipple to go into a 1/4" NPT port.
Unread 29-01-2014, 07:22
AKA: Joseph Martin
Rookie Year: 2011
I see. I would be careful though, perhaps someone should ask about this on the q&a.
Unread 29-01-2014, 08:48
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
Can we agree that "we used it in the past" is not a response.
Thanks.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-01-2014, 09:09
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
There are very few restrictions on the use of "fittings", just be careful in defining a fitting. For example;
A quick exhaust valve is not a fitting, Nor is a check valve, but a 1/4" NPT close nipple is.
Also keep in mind that the 1/8" NPT restriction is for valves, not fittings. It is allowable to use fittings larger than 1/8" NPT, just not valves that have ports larger than 1/8" NPT.
Former Mentor Team 1771
Former mentor Team 4509
Unread 29-01-2014, 11:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The question is do you consider a nipple a fitting or a tube. I would tend to consider a close (short) nipple a fitting (legal). At some point it would transition into a pipe, which it really is, which be closer to tubing (not legal)
Keep in mind I am not the one inspecting your robot.
Unread 29-01-2014, 11:36
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
Thanks for the input. I'm glad to get some backing on my interpretation.
Personally I'm not worried about a "pipe" being mistaken for "tubing". In this area, "tubing" usually means flexible (or at least, bendable). I'm guessing the rule is there to minimize damage if the vulnerable plastic tubing is cut or disengaged, which isn't a risk with hard pipe. I agree the question is probably worth a Q&A (I don't know how to do that though - I'm a first year mentor).
Unread 29-01-2014, 12:01
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
In that case "pipe" is not a fitting & not on the list of approved items. You probably OK with short nipples, without a Q&A only your inspector knows for sure.
Unread 29-01-2014, 12:33
Unsung FIRST Hero
Rookie Year: 1996
The rule was simplified this year as 0.160 ID tubing has the same flow restrictions as saying Cv of 0.32 or about the same flow as 1/8" NPT port diameter.
Al
WB9UVJ
www.wildstang.org
Unread 05-02-2014, 07:18
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
If 1/8" NPT port diameter has a Cv of 0.32, then why would a solenoid with 1/8" NPT output advertise a Cv of 0.75? (mcmaster 6124K511)
Unread 06-02-2014, 13:33
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
Team Role: Coach
Rookie Year: 2007
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Guys,
Thanks.
But Al, I have used that response in the past
Anthony Rubio
Co-Coach, Memento Vitam Team 5484, 2015-????
Mentor, Black Knights Team 135, 2009-2015
Student, Black Knights Team 135, 2007-2008
Unread 06-02-2014, 21:53
DonRotolo's Avatar
Back to humble
FRC #0832
Best. Response. Ever.
  #15   Spotlight this post!
Unread 07-02-2014, 07:33
Unsung FIRST Hero
Rookie Year: 1996
Why do you guys to this to me?
Al
WB9UVJ
www.wildstang.org
