Go to Post Goodness, YES. Please get a copy of the rules. It explains a lot, and if your robot does NOT follow the rules, you will not be allowed to compete. Really, it is very important. - DonRotolo [more]
Unread 28-01-2014, 22:45
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Thumbs up Non-retriggerable one-shot Labview example
Dear Labview CD users,
Has anyone created a FRC Labview non-retriggerable one-shot Labview VI yet?
The function once triggered, completes its' action based on a preset timer amount.
I am contemplating using this function for our shooter. A student presses a button to activate the function. A global variable is used to pass the time and power level to the specified PMW motor controller. Does such a block already exist in the Labview environment or in a Labview library somewhere?
Regards,
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 29-01-2014, 00:41
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Re: Non-retriggerable one-shot Labview example
I don't know if it already was out there but I decided to go ahead and write it.
The actual vi:
https://drive.google.com/file/d/0B4f...it?usp=sharing
A vi demonstration how it can be used, it's very simple and shows how powerful such a simple vi can be. makes it extremely easy to setup a sequence of timed events either one after another or in parallel all with different durations.
Unread 29-01-2014, 00:45
FRC #1658
The actual vi:
Here is what it would look like using the vi i made to do the task you requested http://imgur.com/SAxApmS
