Go to Post devote your life to FIRST. It will pay off. - suneel112 [more]
Unread 29-01-2014, 10:31
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
DLINK NOT COMMUNICATING
Our D-link is not communicating with our driver station. Firewalls are down, IP's are set correctly, Subnet Mask is 255-0-0-0 as it should be for driving - the D-link shows up - I can connect to it - but the diver station never registers a bridge and cant communicate with the robot. It was just working a few days ago.
I am going to re-image the d-link but before I do so I was wondering anyone had any other ideas as to what it could be.
THANKS!
Unread 29-01-2014, 11:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: DLINK NOT COMMUNICATING
Originally Posted by LFRobotics View Post
...the D-link shows up - I can connect to it - ...
Where does it show up, and how do you connect to it? If it's at the proper address (e.g. 10.46.23.1), the Driver Station should be able to detect it.
Unread 30-01-2014, 16:08
jordansch's Avatar
jordansch jordansch is offline
arramos
FRC #0935 (RaileRobotics)
Rookie Year: 2011
jordansch is an unknown quantity at this point
Make sure that the IP address of your laptop, D-link, and cRIO are all different. Another possibility is that the wire between the cRIO and the Dlink is bad, or possibly you need to reimage your cRIO (if you have not already done so this year).
One problem our team ran into a few years ago is that the school started blocking our 2.4 gHz. wi-fi signal. Try switching to 5 gHz (if your computer can run that) and see if that works. (just flip the switch on the D-link, computer should change automatically).
