Go to Post I was surprised how easily Mike hoisted me off the ground. I'm nearly 250 pounds and he lifted me up like I was a soccer ball! :ahh: - Koko Ed [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 29-01-2014, 18:47
michael_lin michael_lin is offline
FRC #4572
michael_lin is an unknown quantity at this point
Bad values for accellerometer
My team has an acellerometer hooked up to SPI through the digital side car. We're using the default ADXL345 Accelerometer that came in the KOP
The only value we can get out of any axis is -26.105, even while shaking it around. Can anyone else diagnose our issue? We're using Java for our control system.
Unread 30-01-2014, 09:58
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Bad values for accellerometer
Did you enable it by setting the measurement bit in the power_cntl register 0x2D ? See attached datasheet page 16.
Unread 30-01-2014, 21:09
FRC #4572
We're using the built in class: ADXL345_SPI.
If I understand correctly, the constructor for the class should already enable the power bit? Or do we have to interface with the accelerometer manually?
