Go to Post As engineers we should aspire to create, not destroy. If this is the case, why would we want to create machines with the sole purpose to destroy? - WakeZero [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 00:25
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Programming the second joystick in PBASIC
Posted by Will Korinek at 2/7/2001 8:40 AM EST
Student on team #646, Mechanical Animals, from Sayville High School and Computer Associates.
Hi just wondering how to go about getting the second joystick to make a pwm go up or down, and the trigger and thumb buttons work as relays.
thanks,
Will Korinek
646 Mechanical Animals
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
You are already done!
Posted by Eric Reed at 2/7/2001 3:57 PM EST
Coach on team #481, NASA Ames / De Anza High School, from De Anza High School and It could be you!.
In Reply to: Programming the second joystick in PBASIC
Posted by Will Korinek on 2/7/2001 8:40 AM EST:
: Hi just wondering how to go about getting the second joystick to make a pwm go up or down, and the trigger and thumb buttons work as relays.
: thanks,
: Will Korinek
: 646 Mechanical Animals
It's already there. Joystick one controls PWM1, Joystick 2 PWM2, etc. through 4. Similarly, the buttons are already programmed to the relays. I think the trigger on joystick one sends relay one forward, and the thumbswitch sends relay one reverse...but that might be backwards.
Good Luck,
Eric
Team 481
#0047 (ChiefDelphi)
Re: You are already done!
Posted by Gregory Ross at 2/7/2001 6:22 PM EST
Engineer on team #330, Beach Bots, from Hope Chapel Academy and NASA/JPL.
In Reply to: You are already done!
Posted by Eric Reed on 2/7/2001 3:57 PM EST:
: : Hi just wondering how to go about getting the second joystick to make a pwm go up or down, and the trigger and thumb buttons work as relays.
: : thanks,
: : Will Korinek
: : 646 Mechanical Animals
: It's already there. Joystick one controls PWM1, Joystick 2 PWM2, etc. through 4. Similarly, the buttons are already programmed to the relays. I think the trigger on joystick one sends relay one forward, and the thumbswitch sends relay one reverse...but that might be backwards.
: Good Luck,
: Eric
: Team 481
All this information can be found in the Control System Users Manual available on the Innovation First WWWeb site (Link below).
The default PWM controls are listed on page 27, and the relay controls are on page 28.
[IMG] code is Off
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
Programming with the PBASIC Tokenizer Raven_Writer Programming 12 05-01-2003 15:27
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
joystick problem archiver 2000 12 23-06-2002 23:08
pbasic programming punarhero Programming 4 21-01-2002 23:32
