Go to Post The GDC has spoken, we have listened and will follow their ruling. - ChuckDickerson [more]
Unread 30-01-2014, 17:42
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
pic: VersaPlanetary Plate with Cams
Unread 30-01-2014, 17:46
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: VersaPlanetary Plate with Cams
This is a pretty slick little setup. I'm curious as to why you need two cams though, shouldn't you only need one to react against the chain load?
If you just have two shown to demonstrate you can put them on either side, ignore my question.
Unread 30-01-2014, 18:13
Chris is me's Avatar
AKA: Pinecone
I could be wrong, but wouldn't a tight bolted connection hold the gearbox in place just fine? Teams slot gearboxes all the time without needing cams to retain them. I could be missing something though.
Unread 30-01-2014, 18:22
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
That would be dependent on load/setup, I've seen multiple setups work and multiple fail.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 30-01-2014, 21:49
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
Yeah, us too. A lot of stuff on FRC bots sees a ton of vibration, which tends to loosen screws. We've had some problems with the plates sliding in the past.
And, yeah, it's just to show that there are two places to put a cam.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
