Go to Post Inside Dave's Head (which is a place I'd like to go someday, but I'm not entirely sure what I'd find)... - Ian Curtis [more]
Unread 30-01-2014, 19:22
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
Robot Losing Communication when strafing right
On our Mecanum drive, we loaded the auto-generated mecanum code from LabView to make sure the motors are in the correct place and we've noticed that the robot loses communication with the driver station when it tries to strafe right.
Since it was generated by LabView it couldn't have been a programming issue, and we've rechecked wiring over and over again and nothing looks wrong. I'll update you guys on wiring tomorrow when I can touch the robot.
The voltage drops only slightly by about .3 or so volts and then the robot doesn't communicate any more. The driver station says that the robot is communicating and that there is code loaded, teleop is enabled as well. But any inputs from the joystick are not read until we re-enable teleop. We've tried with two different Logitech Attack 3 joysticks to see if it's an input error and they both do the same thing.
We had this problem last year as well and we've never figured it out.
Unread 30-01-2014, 19:35
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Robot Losing Communication when strafing right
How is you radio wired? Is it connected through from the regulated 12V output on the PDB, then through the 12V-5V converter?
What is the battery voltage reading when this happens?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 30-01-2014, 19:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I suspect that your digital sidecar isn't properly powered. It gets some power through the DB-37 cable, but not enough to send a full speed PWM to 4 motors. Assuming that your right motors are inverted in code, a left turn is minimum PWM to all motors and a right turn is full PWM to all motors.
Disconnect the DB-37 cable from the digital sidecar and make sure that all 3 power LEDs are brightly lit.
Have you solved your mechanical problems from your previous thread?
Unread 30-01-2014, 20:02
Lord of Lazy
Rookie Year: 2013
Okay, Tuesdays and Thursdays are days left for labor intensive homework so no we have not solved the mechanical issues yet. The mechanical one is harder to fix than the wiring one so we will try the wiring tomorrow after school gets out. Thank you!
As to luckof13, yes the voltage regulator is correct, the voltage drops from ~12.43ish to ~11.5ish then spikes back up to the original voltage.
Unread 31-01-2014, 19:55
Lord of Lazy
Rookie Year: 2013
All 3 LEDs are powered on.
I wouldn't say that losing communication is the best way to describe it. It just stops moving. The driver station is all green and the robot is all green. Jaguars are blinking. It doesn't take any inputs after it "dies". We need to disable teleop and then reenable teleop to get it to take inputs. The Dashboard is showing that the joystick is still giving an input after the "death".
Unread 01-02-2014, 03:27
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
perhaps your code is crashing ? check netconsole and try to find a minimal test case.
Unread 01-02-2014, 13:18
Lord of Lazy
Rookie Year: 2013
I wouldn't know why the code would be crashing? We loaded a WPILib built mecanum program. I'll check later.
Would I need to use a filter capacitor or two to get rid of glitches if that's the case?
Well the problem was that we inverted the motors mechanically and it hurt the robotdrive.
We inverted it in code and it works fine.
