Go to Post Frank is frank, and I like that. - rsisk [more]
Unread 31-01-2014, 19:29
Short Stuff's Avatar
Short Stuff Short Stuff is offline
AKA: Josh Noble
FRC #2594
Team Role: Human Player
Rookie Year: 2012
Short Stuff is an unknown quantity at this point
Non-level bumpers
When our team builds our bumpers do the tops of all the bumpers have to be at the same (or at least very similar) heights? To be more specific: Do the front and back bumpers have to be at the same height as the side bumpers?
Unread 31-01-2014, 19:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Non-level bumpers
Please see Q199 and R22's blue box.
Longer answer: If a bumper section happened to be lower than the rest of the bumper sections, but the bumper was still level and entirely within the bumper zone, I can't see anything that would rule it illegal. However, if the bumper was angled, it would be illegal per R22 (blue box), clarified by Q199.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 31-01-2014, 19:53
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
The same blue box was present in 2013, yet angled bumpers were ok.
Unread 31-01-2014, 20:03
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
No blue box in the bumper section of the 2013 rules says anything about angle of bumpers. I checked the archived 2013 Manual just to be sure.
Past teams:
Unread 31-01-2014, 20:21
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
See question 42 from the 2013 question and answer. It has the exact words from the blue box.
http://www.usfirst.org/sites/default...13_Q_and_A.pdf
If it was good to have angled bumpers with that answer, what rule makes it illegal this year?
Unread 31-01-2014, 21:47
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
As follows:
Q&A is not the rules. Correct? However, Q&A does interpret the rules, and give guidance on following them.
The difference between last year and this year is that this year, the ruling is in the rules, not the Q&A. Admittedly, it is in a blue box, AKA "intent and clarification", but it is still in the Manual.
Note too that the word "overtly" is used. Slight variations from level with the ground would probably be OK, you made the effort, but going from 10" (at the top) down to 7" (at the top) over the span of an 8" bumper would raise flags.
Past teams:
Unread 31-01-2014, 22:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I don't know how you're reading the "blue box". It specifically allows non-horizontal bumpers, as long as they stay in the 2"-10" range. Since the bumper is specified to be 5" high, that lets you slope it a massive 3". Even over an 8" run, I don't see that sloping it at atan(.375) =20 degrees is an "overt deviation", but then I'm not a judge. I think that they're trying to keep you from doing vertical pieces or something else silly, like putting a third row of pool noodle into that 3" of space.
That said, if you're design requires a bumper (or any other part) that you can't be sure fits the rules, change the design, or at least make a backup plan!
Unread 31-01-2014, 22:05
magnets's Avatar
Rookie Year: 2012
The answer to q268 says that angled bumpers are not legal by referencing the blue box, which states they are legal, but don't forget, the blue boxes aren't really the rules like the rest of the manual...
EDIT: that's q199, not 268. oops.
Unread 31-01-2014, 22:29
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
And the answer posted on Q268 as I look at it now (several minutes after your post) says:
2014-01-31 by FRC5030
There is no published answer yet
Also, I read the question in 268 as probably referring to bumpers sloped so that the bottom of the bumper is not below the top of the bumper, since it is to " help aid the ball in rolling into our chassis". That is, sloped like snow plow or a cow catcher, not sloped so the bumper looks like a chevron when viewed from a distance.
Unread 31-01-2014, 22:32
magnets's Avatar
Rookie Year: 2012
sorry that's q199. It explicitly disallows angled bumpers. No doubt about it.
Unread 31-01-2014, 23:48
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Fig 4-8 shows the bumpers being perpendicular to the floor. You really can't tell if they are parallel from the figure despite what the blue box says. I have always interpreted that rule to mean you cannot have "cow catcher" bumpers. We have never had a reason to mount one end of bumper lower than the other or have anything other than rectangular bumper so we never tested the exact meaning.
Currently you can have several bumper segments on on a side each one slightly higher. having the net effect of an angled bumper. Now as dX approaches 0....
Unread 31-01-2014, 22:22
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
There is no explicit requirement that BUMPERS be perfectly parallel to the floor, however the requirement that BUMPERS be constructed per Figure 4?8, the vertical cross-section, does implicitly mean that a BUMPER should not overtly deviate from this orientation.
Emphasis mine. The blue box specifically states that the bumpers are IMPLICITLY required to be as close as possible to horizontal. Not explicitly required to be one way is not the same as specifically allowed to be another way. You're not explicitly required to use any particular fabric on your bumper, but a particular fabric is specifically allowed by implication.
Past teams:
Unread 31-01-2014, 22:26
magnets's Avatar
Rookie Year: 2012
Then, the bumpers of 1114, 67, and 236 were illegal in 2013.
What I'm trying to get at is, if you're committing to a design off an assumption of a sentence in a manual based off a past Q&A answer, you should probably ask it on Q&A for some form of further clarification
I assumed that the interpretation given by the robot inspectors at the CT regional, GTR east, GTR west, Waterloo, Galileo, and the michigan district was correct and that robots that competed in the final match of their division at CMP (in a configuration that they had throughout the whole season) were not illegal. If we say that this interpretation could have been wrong, then it opens a huge door to changes
Unread 05-02-2014, 13:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Magnets,
It is irrelevant at this point that the interpretation was different last year. It is this year's Q&A that has answered the question as it applies on Feb 5, 2014 to 2014 robots.
Al
WB9UVJ
www.wildstang.org
________________________
  #15   Spotlight this post!
Unread 05-02-2014, 13:38
Chris is me's Avatar
AKA: Pinecone
"No" is unambiguous, but if bumpers have to be parallel to the floor, why does the manual say bumpers don't have to be parallel to the floor? Why not just change the blue text to say "bumpers must be as close to parallel to the floor as reasonable"?
Obviously angled bumpers are illegal if they say they're illegal, but I don't understand how the GDC would expect teams to interpret identical wording differently in different years.
