Go to Post Whatever you do though, don't get into an "us versus them" mentality with your mentors. They are there to help. - Bongle [more]
Unread 31-01-2014, 19:45
RaxusPrime's Avatar
RaxusPrime RaxusPrime is offline
Driver and Programming Captain
AKA: Brennen Martin
FRC #3883 (DataBits)
Rookie Year: 2013
RaxusPrime is on a distinguished road
IMAQ Error
Hey,
We are having a problem. An error always shows up when we try to run the vision example in our code.
Here is the error:
Does anyone know how to solve this issue? Team 3883
Unread 31-01-2014, 19:51
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: IMAQ Error
Can you post a screenshot of your code?
If you're deploying to a robot, some of the vision functions aren't available in the cRIO image.
Unread 31-01-2014, 22:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: IMAQ Error
Similar issue here: http://www.chiefdelphi.com/forums/sh....php?p=1329269
Unread 01-02-2014, 13:23
RaxusPrime's Avatar
AKA: Brennen Martin
Rookie Year: 2013
Re: IMAQ Error
Here it is:
Unread 01-02-2014, 17:02
RaxusPrime's Avatar
AKA: Brennen Martin
Rookie Year: 2013
Re: IMAQ Error
I went to the source of the error and this was the block diagram of that IMAQ AVI12 vi. Here it is:
Unread 01-02-2014, 23:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: IMAQ Error
I think the Case block labeled "Get image from camera or file" is only supported when running the vision code on a PC target. It includes the WPI_CameraRead MJPG for Dashboard.vi function, which calls the IMAQ AVI2 Create function a few levels deeper. If you aren't running the code as part of the Dashboard, you shouldn't have that there.
It looks like you copied and pasted the vision example code instead of following the steps in Tutorial 8, Part 4.
Unread 02-02-2014, 23:18
RaxusPrime's Avatar
AKA: Brennen Martin
Rookie Year: 2013
Re: IMAQ Error
I wasn't aware there was a tutorial, would you mind posting a link to it? By the way thanks for the information, this error has been stumping us for quite awhile now.
Unread 03-02-2014, 00:38
Software Architect
Re: IMAQ Error
When you launch LabVIEW, it opens the FRC 2014 Getting Started window. A number of tabs are available on the window's left side. The second one down is Tutorials. Click it and you will find a wealth of instructional help listed.
Unread 03-02-2014, 11:32
RaxusPrime's Avatar
AKA: Brennen Martin
Rookie Year: 2013
Re: IMAQ Error
Awesome, thank you so much!
