Go to Post When we find bugs at work, we don't ask "who wrote that section of code?" We ask "Who is the best, most knowledgeable person to work on fixing this bug?" - Jon Stratis [more]
Unread 01-31-2014, 08:27 PM
AutoBotAM AutoBotAM is offline
AKA: Christian Reese
FRC #2077 (Laser Robotics (Laserbots))
Rookie Year: 2010
AutoBotAM is an unknown quantity at this point
Parallel commands that depend on the same subsystem?
How would the two commands be ran in this situation? Either by running them in parallel in a command group, or if both commands were default commands of different subsystems.
I know that if one command is run that depends on a subsystem that another running command depends on, either of the commands are terminated depending on the circumstances. Is there a way to get two commands to literally run in parallel, accessing the same subsystem? So if commands A and B depend on subsystem C, the scheduler will execute A, then B, A, B, and so on.
Is there a way to get that working?
EDIT:
If there is not, I'll explain my design further. In this case command A would only read information from subsystem C. It would only use accessor methods and no mutator methods. So would it be safe to just omit the "requires" call?
"Mecanum drivetrains, like every other, have advantages and disadvantages, but some of the disadvantages being discussed here are overstated and/or misinformation." -buchanan
