Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 02-01-2014, 09:55 AM
toastergod's Avatar
toastergod toastergod is offline
Programming Wizard
AKA: Sam Lehman
FRC #0279 (Tech Fusion)
Rookie Year: 2013
toastergod is an unknown quantity at this point
Displaying Data in the Driver Station Output
I have written a program that is supposed to take a value given by a potentiometer, and display it in the driver station output. I have tried using
"System.out.println();"
however this does not output to the driver station. I then attempted to use
"driverStat.println(DriverStationLCD.Line.kMai n6, startingColumn, "Potentiometer: " + POT.get());".
This however does not output anything either. Any fiddling with the potentiometer will not display anything.
Here is my full code:
TF_PrintPot.java:
Code:
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package POTcheck;
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.AnalogPotentiometer;
public class  TF_PrintPot {
    public AnalogPotentiometer POT = new AnalogPotentiometer(1,1);
    public DriverStationLCD driverStat = DriverStationLCD.getInstance();
    public int startingColumn = 1;
    public TF_PrintPot() {
    public void pot () {
        System.out.println(POT.get());
        driverStat.println(DriverStationLCD.Line.kMain6, startingColumn, "Pot " + POT.get());
        driverStat.updateLCD();
TestProject.java:
Code:
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package POTcheck;
import edu.wpi.first.wpilibj.SimpleRobot;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class TestProject extends SimpleRobot {
     * This function is called once each time the robot enters autonomous mode.
    public TF_PrintPot POTrun = new TF_PrintPot();
    public void autonomous() {
     * This function is called once each time the robot enters operator control.
    public void operatorControl() {
        while(true) {
            POTrun.pot();
     * This function is called once each time the robot enters test mode.
    public void test() {
I have attempted to search in and outside of Chief Delphi and I have not found anything. Thank you for your assistance.
