Go to Post FIRST, for me, is about mental wrestling with oneself through the ideas of others and learning through this dialogue. - sammyjalex [more]
Unread 01-02-2014, 13:49
Cyborg Mustang's Avatar
Cyborg Mustang Cyborg Mustang is offline
FRC #2647
Cyborg Mustang is an unknown quantity at this point
Jaguar Questions
Hello, community. We (Team 2647) are pretty sure that our jaguar that we just bought from Vex arrived broken: though it is hooked up in the same way that all of the others are (wired, correct polarity, to higher-power ports on power distribution board; PWM to the PWM Out on the digital sidecar) it does not light up nor give a non-zero voltage reading on the output to the motors.
Two questions, quickly:
-First, is there some kind of thing that must be done to somehow initialize a jaguar that we just failed to do, as in some special method of using it on the first time we run it?
-Second, do any of you know what Vex's return policy is? We've been looking around but we've had some problems finding it.
Thank you, and have a fine day!
Cyborg Mustangs Team 2647
North High School
Phoenix, AZ
Unread 01-02-2014, 13:58
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Re: Jaguar Questions
There is no out-of-box initialization that must be done for a PWM-controlled Jaguar. There is configuration for using them with CAN.
Back to the beginning now though, are you saying when you wire it to the PDB that the LED on the Jag does not light up at all? check your PDB (just for my sanity) make sure there is no red LED light showing on the PDB saying that either A) your breaker is tripped, or B) there is no fuse installed on the PDB power ports you plugged your Jag into.
If the above don't solve your problem you are the proud owner of a broken Jaguar motor controller and you should contact VEX customer support.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 01-02-2014, 14:00
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
No LED at all? Have you measured the input voltage?
No
See http://www.vexrobotics.com/policies
Unread 01-02-2014, 18:10
FRC #2647
Yes, that was the first thing we checked. Furthermore, the voltage is indeed arriving at the jaguar, according to the multimeter readings. We think it is indeed broken: we never had to do anything to initialize a jaguar before, but we thought it was worth checking.
Originally Posted by Joe Ross View Post
Thank you, that was helpful. Not sure why that did not show up on our google search.
North High School
Phoenix, AZ
Unread 05-02-2014, 15:23
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
What did you find out?
