Go to Post 1. Build a robot. 2. Don’t let it get destroyed. - B-Bot [more]
Unread 01-02-2014, 19:30
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
Can I implement Scaling factor in PWM?
Because the motors are not running the same speed as each other.
Unread 01-02-2014, 19:40
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Can I implement Scaling factor in PWM?
I assume this is for your drivetrain?
It's better to try to find the source of the problem, if you can, and fix it.
What symptoms are you observing that leads to your conclusion that the motors are not running at the same speed?
Have you calibrated all of the motor controllers in situ?
What kind of drivetrain? (e.g. 4 wheel skidsteer, 6 wheel drop center, mecanum/omni, chains/belts/straight-off-the-gearbox-output-shaft, etc).
What kind of operator interface? (e.g. Arcade, Tank, etc)?
Have you noticed that some of the motors are getting noticeably hotter than others?
What are the DS diagnostics telling you about your joystick values and your PWM commands?
Unread 01-02-2014, 20:20
Lord of Lazy
Rookie Year: 2013
Yes for my drivetrain.
The problem is the resistance for each motor is different (I assume) because it's a custom built chassis and it isn't machined by a master machinist in the business for 101 years, it's drilled by 16-18 year old students. That's not exactly something we can fix.
What do you mean by situ?
We're using mecanum drive.
Sometimes Yes.
Not sure about what you mean by that last question.
Unread 01-02-2014, 20:53
Ether's Avatar
Rookie Year: 1969
The idea is to fix the drivetrain, not the students
http://www.thefreedictionary.com/in-situ
chains/belts/straight-off-the-gearbox-output-shaft?
What kind of operator interface? 3-axis joystick? Two 2-axis joysticks? Something else?
Sometimes Yes.
Sometimes Yes what? Some motors getting hotter than others?
Are you using the same model motor controller for all 4 motors?
Diagnostics on driver station and dashboard.
Unread 02-02-2014, 13:18
Lord of Lazy
Rookie Year: 2013
When we put it on blocks, creeping the robot forward not all the motors run the same speed. At full throttle and full reverse it all goes relatively the same.
Using 4 Jaguars straight of the gearbox output shaft. We're using a Logitech Xtreme 3D joystick with twist. The test was made using a Logitech Attack 3.
We are using Black Jaguars for all of them, and only one of them gets a little more hot. It's not that much of a difference.
I haven't been able to touch it since then since we're building on the chassis at this point in time. I'll update you on that when everything's mounted.
Unread 02-02-2014, 14:31
Ether's Avatar
Rookie Year: 1969
That doesn't sound too unusual. Does it affect the way the vehicle drives? If so, how? (This is important to know, in order to make suggestions for correcting it).
How difficult would it be to swap the hot motor with one on the other side, and see if the problem follows the motor or stays on the same side.
You haven't said yet, but if the problem is manifesting itself as undesired behavior while driving (and not just an observation made while the bot was on blocks), and if you are unable to identify (or correct) the root cause, you may be able mitigate it by using a gyro (about which more later).
Unread 02-02-2014, 17:38
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Rookie Year: 2011
Dexterium is an unknown quantity at this point
My team encounters this problem on every robot we make. We usually blame gearboxes and chains and forget a mechanical fix for it. The best way to augment the drive control is to place a gyro on the robot. While this is not a direct fix for the problem it treats the symptoms. The gyro detects the direction the robot is moving, compares it to the command from the joystick, and corrects the difference. The mecanum drive block has a place for a gyro input. All you have to do is pop the gyro on the bot (dead center) and connect it to the block.
Unread 02-02-2014, 22:48
Lord of Lazy
Rookie Year: 2013
The vehicle drives great in every which direction except for strafing along the X axis. Our chassis is a custom built one that we forgot to implement ease of access to (terrible but hey learning experience).
We're going with CAN mode (which I'm not too terribly sure how to set up) on the Jags so we can implement encoders for Auton mode, and we tried implementing a gyro today but it didn't work out so well. It's wired up but I'm not sure how to code it. The mecanum drive block has a Gyro input but I don't know what to put into it. We have driven it on ground and it's great except for X-axis strafing.
Dexterium, would you mind if you posted an example of plugging the gyro into the block? Do you have to initialize the gyro in begin.vi?
Unread 02-02-2014, 23:39
Ether's Avatar
Rookie Year: 1969
What happens when you try to strafe along the X axis?
Unread 03-02-2014, 00:05
Lord of Lazy
Rookie Year: 2013
Strafing along the X the robot ends up rotating (before we used the Extreme 3D stick) because of what I can only assume is some motors are running way faster than the others. Again, this only happens during creep strafing. Full speed strafe is not a problem, but we would like low speed strafing for autonomous.
Thanks for all the help you provided so far by the way, my team and I appreciate it!
Unread 03-02-2014, 00:49
Ether's Avatar
Rookie Year: 1969
I'm a bit confused. Which of the following meanings is the intended one:
1) You used to have the problem when you were using the Extreme 3D joystick, but you aren't having the problem now
2) You used to have the problem, but you aren't having the problem now that you are using the Extreme 3D joystick
3) You didn't have the problem when you were using the Extreme 3D joystick, but now you have the problem
4) You didn't have the problem, but now that you are using the Extreme 3D joystick you have the problem
5) Something entirely different?
What diameter mec wheels are you using? And are they VEX or AM?
Have you tried temporarily disabling rotation and forward/reverse in your code (simply by multiplying those axes by zero) and then running the robot to see how well the strafe behaves?
Check all the rollers on each wheel. Do they all spin freely? Or are some "dragging" somewhat? Do all the rollers have the same amount of axial free play, or is there a lot of variation? Some of the models of affordable mec wheels used in FRC robotics can display the symptoms you are describing if they are not meticulously assembled and adjusted.
If your attempts to locate and correct the root cause of the problem are not successful, a gyro can be used to help minimize rotation of the robot (when you don't want rotation).
Unread 03-02-2014, 10:24
Lord of Lazy
Rookie Year: 2013
Oh no we're having this problem with both joysticks but I wanted to rule out twisting the joystick while strafing as a factor. We removed both y and rotational axis to see if it would happen and it did.
We are using 6 inch andyMark wheels (big metal ones). We are implementing a gyro and shaft encoders to solve the problem. I just don't know where to plug the gyro in from teleop.vi.
