Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 01-02-2014, 21:08
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
pic: Bad Anderson Connector
Unread 01-02-2014, 21:09
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: pic: Bad Anderson Connector
Report this to FIRST HQ as soon as possible. This happened last year too, and they had to send out massive warnings.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 01-02-2014, 21:14
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
My paranoia went up 100%....I'll never look at a Anderson the same way again
Unread 01-02-2014, 22:43
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
So long as all your connectors are that way you'll be fine...
Right?
Jason
Unread 01-02-2014, 22:48
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Right?
Jason
Right, but *most* teams assume that the connectors are always the right way before attaching them, which can in cases like this cause extremely costly consequences. Also, I am pretty sure that this would be considered a violation of [R49]:
Originally Posted by FRC Game Manual
All non-SIGNAL LEVEL wiring with a constant polarity (i.e., except for outputs of relay modules, motor controllers, or sensor outputs) shall be color-coded as follows:
A. Red, white, brown, or black-with-stripe on the +24VDC, +12VDC, and +5VDC connections
B. Black or blue for the common or negative side (-) of the connections.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 03-02-2014, 22:58
AKA: Jason Brett
Sorry... I should have added a smiley, eh? You're quite right that wiring your robot this way would be a problem when it comes to sharing batteries or chargers with other teams.
But I'll suggest that it wouldn't be a violation of R49 so long as the red wire was attached to the positive battery terminal. There is no specific regulation requiring that labels or other markings match the wire colour, or that labels and markings be correct, only that the colour be correct. It could be argued that incorrect labeling falls under the catch-all areas of potential safety hazard, or failing to meet good engineering practice... but the "rules geek" in me has to point out that R49 is only about colour.
Jason
Unread 05-02-2014, 03:07
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
We had one of these today. Unfortunately it wasnt one from the KOP, it was one of these
http://www.andymark.com/product-p/am-0009.htm
Was kinda frustrated, but at least we know how to fix them.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
2011-2012 865 Mentor
2006-2008 1814 Team Captain, Main Driver, Mechanical
Unread 10-03-2014, 19:42
AndreaV AndreaV is offline
That girl with chips in her hair.
FRC #1360
Team Role: Mechanical
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
As Donkehote mentioned 5031 got one of these flipped connectors from Andymark. We flipped the leads as suggested.
This past weekend our alliance captain, team 2013, The Cyber Gnomes needed a battery in the quarter finals. We lent them one of ours, this battery was dubbed "Omega".
With 90 seconds left the Gnomes got bumped and lost all power. Our one point dump defense bot and our alliance partner 4825 somehow miraculously squeaked out a win (actually I know how, tech fouls, the same kind that had lost us the match before and after this occurrence, oh wait that's another thread.)
After inspecting the battery it was clear that Omega's negative terminal slipped out. This should have cost us a quarterfinal match. No blame should go to Andymark, as they express shipped us a replacement lead right away, however in the excitement of build season this got overlooked. Omega served us well during build practice, and multiple practice and qualifying matches at GTRE. These things have a way popping up at the worst of times.
We felt horrible taking away the gnome's 2nd last chance to play at GTRE. Don't let this happen to you! If you have one of these flipped leads, toss it! It's not worth the risk!
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2012 FRC 4258 TSS Robotics Newbie Mentor
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
Unread 29-03-2014, 22:04
tbarban's Avatar
tbarban tbarban is offline
FRC #4825 (The Coltenoids)
Rookie Year: 2014
tbarban is an unknown quantity at this point
So that's what happened. I was only told by 2013 that it had to do with the battery, makes sense now.
Unread 30-03-2014, 13:35
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
It is the last thing that one would expect, QC process should have caught this at vendor's site. In 2012 the flat ribbon connecting cRIO and DS was reversed too!
Unread 01-02-2014, 22:50
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
This happened to us last year. See here:
http://www.chiefdelphi.com/forums/sh...derson+warning
The good news is that it's an easy fix. All you need is a screw driver to switch the wires around by prying the connector contacts.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
