Go to Post There was no real separation between who did what. "we" did it all and it was fun. - Team2339 [more]
Unread 02-02-2014, 13:06
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Diameter of Air Cylinder for VexPro 3 stage Ball Shifter Winch ???
Anyone know for certain what diameter air cylinder is used to reliably and consistently release a 3 stage ball shifter winch under heavy load ?
If its more than the stock one, how did you mount it ? A pic would be great.
Also, might as well as what travel required ? I am guessing 1/2" (We are new to this product).
Unread 02-02-2014, 13:13
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Re: Diameter of Air Cylinder for VexPro 3 stage Ball Shifter Winch ???
According to Paul Copioli the regular 3/4 inch bore and 1/2 stroke pancake cylinder can shift up to 400 lbs of pressure before something larger is needed. Here is the quote:
Originally Posted by Paul Copioli View Post
You can simply remove the input gear for the high speed gear stage. That is the easiest way.
We are testing this now to see the max loading the ball shifter can still shift into neutral. My theoretical calculation indicates in excess of 400 lbs in a 2" diameter winch.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 02-02-2014, 15:36
de_ de_ is offline
AKA: Dave Edwards
Thanks. I wasn't quite clear if he was saying the air cylinder would also do 400 or just the winch hardware. I've posted a question on the link you quoted.
