Go to Post You really can't have a bad year. The only way you can is to come out of it and not learn anything. - Dan Petrovic [more]
Unread 02-02-2014, 20:03
bartv bartv is offline
FRC #4946
Rookie Year: 2014
bartv is an unknown quantity at this point
Talon ground
Hi,
Our team has mounted four talons to an aluminum backplate. When I test the ground between the chassis and the talon, I get open circuit on each of the electrical connections (good!), but the heatsink has a ground connection.
Is this acceptable? We are putting an insulator between the cRIO and the aluminum; is the same needed for the Talons?
Thanks!
Bart.
Unread 02-02-2014, 20:22
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: Talon ground
Check the blue box under <R37> in the 2014 FRC Manual. The inspectors will be looking for at least 10K Ohms between either (+) or (-) Anderson Power Pole terminal that is connected to the PD board and the robot chassis. You might want to check for at least ten times that resistance between any Talon terminal and its heatsink, if you will be attaching several Talon heatsinks to your robot's chassis. To be safe, isolate the Talons.
Richard Wallace
since 2003
Unread 02-02-2014, 20:23
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Talon ground
The test is to measure the resistance between the PD +/- and the frame. Any other part of the talon & ground is not controlled by the rules
In other words "there is no rule that prohibits this."
Unread 03-02-2014, 18:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Talon ground
The heatsink has a ground connection? I'm not sure what you mean. Are you saying that the aluminum heatsink, when screwed down to an aluminum plate, is conductive? (I would hope it is; it's aluminum).
The check you MUST pass is: With the battery disconnected, measure resistance betwene the + PDB connection and metal chassis, and between - PDB connection and chassis. Resistance MUST be greater than 10k Ohms (try for much more). IF you pass that test, you're good to go.
