Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 03-02-2014, 03:34
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: 2471's final winch assembly gear side
Unread 03-02-2014, 03:36
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Re: pic: 2471's final winch assembly gear side
Color me impressed. That's a really neat little assembly.
Have you done any testing to see if you can get enough torque out of the PG-71 gearbox? In the past, we've had some problems with them failing at high torque loads.
Also, could you give us a bit more info on final ratio/load/travel/windup time/current for the system?
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 03-02-2014, 09:18
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
That looks nice, very well integrated components. I wouldn't worry too much about the PG71, we used two of them to lift our robot up the pyramid last year over 60 times with a 1.5" pulley. If two PG71's can dead lift 142 lbs over 450 feet in one season, I'm pretty confident that it can pull back your shooter. Then again, how much tension are you pulling back?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 03-02-2014, 14:00
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
Thanks. We haven't done any testing of the torque output yet. But the numbers say that it will be more than enough power.
The 18 volt 775 stalls at 166oz-in of torque or 10.3lb-in. After a 71:1 gear reduction that's 735lb-in. Our spool only has a 0.625" radius, so under perfect conditions it should stall producing 1180lbs of force. Multiply this by a rough torque efficiency of 0.75 and you get 880lbs.
Our shooter should take less than 200lbs to retract so the motor will be running in its happy place (about 10,000rpm) which should pull our cable at about 10in/sec. So it should get the job done in a little over 1 second. Of course it's all theoretical at this point.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 03-02-2014, 16:51
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
How is that ratchet released? is the tension taken off for the release?
Unread 03-02-2014, 16:53
amesmich's Avatar
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
Disregard, I see in the other picture you used a cylinder to slide it.
Unread 03-02-2014, 17:11
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
I think you've got the idea, except the cylinder does not directly slide the ratchet. The cylinder just disengages the spool from its shaft, so the ratchet is always engaged.
Unread 03-02-2014, 19:13
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
Interesting. Our 2 CIM worm gearbox with about an 80:1 final reduction with a 1" diameter pulley takes about 3 seconds to pull back our 130 lb shooter. I'd be interested in hearing your results when you test it on the robot.
-Plutarch
Unread 04-02-2014, 02:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
We did our first tests of the system as whole today. I'd say it took about 2 seconds to retract our shooter. It measured at over 100lbs of force in its current configuration.
We did have an issue with triggering the shifter rod, but I expect that it will be fixed with some lubrication. Like one of our mentors always says "When in doubt, Lubricate!"
