Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 03-02-2014, 14:27
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Intermittent cRIO connection
We've been having some problems connecting to the cRIO. On the driver station it goes back and forth from red to green. I've confirmed that the computer can connect to the robot correctly, so I know it's a problem with connection to the cRIO.
Any ideas?
Unread 03-02-2014, 14:45
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Intermittent cRIO connection
Are you talking about the Communication light on the Driver station?
Is your code currently executing on the cRIO?
Are you Ethernet wired or wireless?
When you say that your computer can connect directly to the robot, is that wired?
Who is the "robot" in this context - the radio or the cRIO?
Unread 03-02-2014, 14:52
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
Team Role: Coach
Rookie Year: 2007
steinra is on a distinguished road
Going back and forth on green to red for which item? Communications or robot code, or both?
Have you tried running a continuous ping in a command window to see if you are dropping pings the same time the green to red occurs?
(windows)
ping -n 1000 10.xx.yy.2
or
ping -t 10.xx.yy.2
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
Unread 03-02-2014, 15:37
cgranata cgranata is offline
Team Captain
FRC #1396 (Pyrobots)
Team Role: Electrical
Rookie Year: 2010
cgranata is an unknown quantity at this point
Did you guys confirm it isn't anything electrical. A few years back we kept losing connection to the cRio and it turned out to be the wire connection to the cRio was very loose.
Unread 03-02-2014, 18:10
AKA: Ethan
Rookie Year: 2012
We have confirmed the problem: the driver station is connecting to the simulated robot. We've told LabView to deploy to the robot (it's set to the cRio in the bottom left corner), but still nothing.
Unread 03-02-2014, 20:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Can you go into a little more detail on this? Do you actually have a simulated robot running? How are you telling LabVIEW to deploy to the robot? What exactly do you mean when you say "deploy"? What is set to the cRio in the bottom left corner? The bottom left corner of what?
Unread 04-02-2014, 08:26
If the DS is connecting to a simulated robot, that means that a computer on your subnet is currently running the simulator. The simulator announces itself to the DS and the DS ignores the robot. The timing of the loop of the simulator announcements is pretty slow, and it will sometimes flicker a bit.
I suspect that your robot code really was downloaded according to the target label in the lower left.. It may even be running. But it is being ignored by the DS.
Greg McKaskle
Unread 04-02-2014, 14:02
AKA: Ethan
Rookie Year: 2012
Thanks all. It turns out that the simulation was left on and LabView was trying to run the simulation with code deployed on the robot.
