Go to Post "Well, geez, I can't figure this out. I cut the piece [I]three times[/I] and it's still too short!" - joshsmithers [more]
Unread 03-02-2014, 21:25
gizmo720 gizmo720 is offline
FRC #1719
Rookie Year: 2010
gizmo720 is an unknown quantity at this point
Programmaticly adjust axis M1011 settings
My team just worked out how to programmaticly adjust settings such as exposure on the axis M1011 camera, and I thought I would share what we found with the community.
First, if you are trying to change camera settings, you should look at the wpi library first, as it has many options already available with an easy API. However, if you are using the M1011, you may notice that some options that are available on the web UI (such as exposure) are not exposed through the wpi library, and do not have a documented API in the camera manual.
We found that these settings could be changed directly using httprequest of the form:
Code:
http://10.te.am.11/sm/sm.srv?<parameter>=<value>&action=modify
The likely incomplete list of parameters that we found (along with default values) is:
Code:
root_ImageSource_I0_Sensor_ColorLevel=50
root_ImageSource_I0_Sensor_Brightness=50
root_ImageSource_I0_Sensor_Sharpness=50
root_ImageSource_I0_Sensor_Contrast=50
root_ImageSource_I0_Sensor_WhiteBalance=auto
root_ImageSource_I0_Sensor_ExposureValue=50
root_ImageSource_I0_Sensor_Exposure=flickerfree50
root_ImageSource_I0_Sensor_BacklightCompensation=no
root_ImageSource_I0_Sensor_ExposureWindow=center
zoneType=other
root_ImageSource_I0_Sensor_ExposurePriority=0
root_ImageSource_I0_Sensor_MinExposureTime=10000
root_ImageSource_I0_Sensor_MaxExposureTime=10000
root_ImageSource_I0_Sensor_MinGain=0
root_ImageSource_I0_Sensor_MaxGain=0
You will need to authenticate yourself before the camera will accept a command. If your http library does not support authentication, you can likely change the URI to
Code:
http://FRC:FRC@10.te.am.11/sm/sm.srv?<parameter>=<value>&action=modify
Unread 04-02-2014, 08:33
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Programmaticly adjust axis M1011 settings
Are there any other actions that you know of? It would be nice to be able to read the known keys and save them when the user modifies them.
