Go to Post Some things can only be revealed by time. - ChrisH [more]
Unread 03-02-2014, 22:31
tcjinaz tcjinaz is offline
Tim
FRC #3853
Rookie Year: 2011
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
The SAM Thread
OK, I was excoriated for this suggestion in 2012, but was proven correct that it was possible and, apparently, reasonable. Can (and may) a robot interfere with a ball in flight by shooting a ball at it?
I'll give you the reality that there are only 10 seconds (generally) when more that two balls in play, so the strategic value of ack-ack is greatly reduced over Rebound Rumble. Is it worth interferrng?
Tim
Software Mentor
3853 Pridetronics[
Unread 03-02-2014, 22:57
Andrew Lawrence
Posts: n/a
Re: The SAM Thread
Is it possible? Yes. Is it worth attempting? No.
Unread 04-02-2014, 08:42
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: The SAM Thread
Check with PFreivald and 1551, they might have an interesting take on this
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 04-02-2014, 09:42
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: The SAM Thread
Best-case its a net-sum-zero strategy, so if it fits into your game plan it might be useful.
I cannot figure out how it would be genuinely useful though.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 04-02-2014, 09:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: The SAM Thread
Dodgeball immediately jumped to mind.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-02-2014, 10:24
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: The SAM Thread
Coming out ahead in auton and locking the score. Ranking suicide in quals but could be a useful strategy if you know you've got them in auton but they can cycle faster.
Unread 04-02-2014, 10:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: The SAM Thread
I suppose so. I guess I was assuming that if you were consistently winning auton (i.e. reliable high-goal shooting) that you would always wind up with better cycle scores.
Do you really think trying to hit a ball out of the air with another ball would be better than a 2 or 3 robot defensive blockade?
Unread 04-02-2014, 10:32
FRC #0079
Rookie Year: 2000
Re: The SAM Thread
Not at all. Hitting a quickly moving target is NOT a trivial problem in the least.
You did ask for a case when it would make sense, not a case in which I would do it.
Unread 04-02-2014, 10:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: The SAM Thread
Touche good sir!
