Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-02-2014, 07:12
kd008702's Avatar
kd008702 kd008702 is offline
AKA: Kevin Daniels
FRC #2642 (Pitt Pirates)
Rookie Year: 2007
kd008702 is an unknown quantity at this point
Exclamation Problem with serial can coms!
We are trying to use can this year for first time. We are using the serial comms. Have set up ID's on all four JAGS using BD-Comm. Have updated firmware. Checked and re-cheched and checked connections one more time. Formmated CRIO for CAN coms with Net console enabled. What we get is We can plug into each individual LAG from the CRIO and talk to it correctly, But can not get the CAN Network to function. Need a little nudge in the right direction to figure out what that ONE little piece is that we are missing.
Also we have 100ohm resistor at both ends of the network. We have tried using both JAVA and LAB view for program and get the same results in both.
Thanks.
Kevin Daniels
Senior Tech.
Pair Electronics
Greenville, NC
