Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
  #16   Spotlight this post!
Unread 06-02-2014, 11:42
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: AC motor?
Originally Posted by pmahoney14 View Post
Would it be simpler to use a DC motor and convert AC to DC? I really need a motor to plug into a standard household outlet.
You could use a computer power supply to generate the 12VDC at decent enough wattage's for your application. 15lbs from a lead screw is not demanding very much.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
  #17   Spotlight this post!
Unread 06-02-2014, 12:33
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: AC motor?
You can use a Variable Frequency Drive and a 3 phase motor - that will do exactly what you want, including braking.
Of course, it will set you back $200 ...
Examples:
VFD
Motor
  #18   Spotlight this post!
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
Re: AC motor?
Depending on what you have available, you _could_ use a three-phase AC motor with a starter.
I'm not sure of the cost, but I'm sure there is a threshold at which the extra cost of that would outweigh the cost of the needed DC converter (Reason #1 why we don't have DC motors on our farm, only AC)... and that for 15 pounds, you are much under that threshold.
I've hiijacked a UPS as a highish-amp testing DC power supply right now. You could do something simalar: just wire into the battery of it to power a CIM, so you have a high amount of juice in reserve but it is constantly recharging- this would work if you don't need continuous use. You wouldn't need to use a UPS; a simple battery charger should work.
For control of DC you should be able to do something as simple as the pseudo H-bridge in a Spike Relay... And with two or one switch instead of relays and signals.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
