| Thread Tools |
Rating:
Display Modes |
pic: 1648 Painted Frame / teaser 2
Re: pic: 1648 Painted Frame / teaser 2
Very nice, is there any reason that you don't just drill through the 80-20 for the cross braces to get rid of those angle brackets? Could cut down on some weight.
The angle brackets allow us to easily modify the position of the crosspieces if needed, and the gussets allow for a more rigid structure and evenly distributed load.
80-20 is heavier per length than comparable strength box tubing. It's not a misconception. Due to the profile it's also less stiff in some dimensions (especially torsion of the bar).
If you can get the weight out elsewhere (through use of lighter joints or other fabrication methods as a result of the 80-20 profile), then it might be lighter. But, thinwall box tubing with bolted/rivited gussets (vexpro style) is definitely lighter than the same thing made of 80-20. I'm curious what the weight of OP's chassis as painted is. |
Decreasing the wall thickness to match the equivant 80-20 stiffness, it would be lighter. |
We haven't weighed the frame yet, but according to inventor, we're looking at about 15 pounds without paint.
Would you mind pointing me to the data that backs this up?
#10
For bending, I constrained both ends of a 1' beam and applied a load to the top face. For torsion, I constrained one end of the same beam and applied a torque to the other. 100lbf load on top face of section, ends constrained: 0.001536" max deflection 8020 (load split between two top flanges on either side of groove) 0.001614" max deflection 0.063" 0.001006" max deflection 0.125" 200 in-lbf torque at end of section, other end constrained: 0.1311" max deflection 8020 0.01055" max deflection 0.063" 0.006772" max deflection 0.125" The weight of 8020 vs 0.125" 1x1 box is virtually the same, 0.063" would be roughly half. |
#11
Cool, thanks for the info.
