Go to Post Gotta love those free-range robots! Yum! - petek [more]
Unread 04-02-2014, 13:45
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Programming Camera
I am programming the camera for the first time. I would only like to program the camera for a image for assistance for the the driver. Help needed....
Unread 04-02-2014, 13:48
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Programming Camera
The only thing you'll need to do is run the camera configuration tool provided wit h the frc utilities. That will set the IP address of your camera and it will appear on the dashboard.
Unread 04-02-2014, 19:43
FRC #1605
okay thank you for the help...
Unread 05-02-2014, 08:58
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Rookie Year: 2011
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
We are having it where our camera tells us if we are lined up for a shot and will put a green border around the image on our computer
If you want to do something like that, use NI Vision assistant. It is very helpful and pretty easy to understand
Unread 06-02-2014, 16:20
FRC #1605
Well I did all the setup/configuration needed for the axis camera but there is no image coming up on the frc dashboard. Also i want to program the camera to look for the target and position the robot accordingly(in autonomous). how can i do that? I am programming in java(netbeans)
Unread 06-02-2014, 16:55
Slave to the bot
AKA: Chad Krause
Team Role: Driver
Rookie Year: 2011
Make sure the IP address of the camera is correct. If I can remember clearly it should be like 10.te.am.11 (I would double check if I were you)
As for auto aiming, that's pretty tricky to perfect. You have to first find the goal, which you do by putting a ring of LEDs around the camera, then looking for that color in the NI vision assistant. Its more complex, but also pretty straightforward.
Look at this page
It is straight from first and wpilib
The basic steps after you find the target is to find the distance then program your robot to move that distance (normally with a PID)
You also want to do all your processing on the dashboard. It is much faster than the crio and processing images. Also get a good laptop, that also helps a lot too
Unread 06-02-2014, 17:28
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
are you planning on processing/advanced functions or just regular camera feed? Both said, you could write an OpenCV application for just a camera viewer and that will allow you to resize the view, etc.!
Unread 06-02-2014, 19:06
FRC #1605
I did check and it is correct but it still won't display on the FRC dashboard
Unread 06-02-2014, 19:26
Ultracrepidate's Avatar
Ultracrepidate Ultracrepidate is offline
Nicole B.
AKA: Nicole B.
FRC #0771 (SWAT)
Rookie Year: 2012
Ultracrepidate is an unknown quantity at this point
Have you tried pinging the camera using command prompt?
Unread 07-02-2014, 09:31
It was mentioned in other threads, but be sure to click the enable button next to the image display.
Greg McKaskle
