Go to Post Stop making me want to spend money on books! I don't need any more good influences in my life!!!! - FourPenguins [more]
Unread 04-02-2014, 14:02
themollykelly themollykelly is offline
FRC #2495
themollykelly is an unknown quantity at this point
Why is the case structure name red?
I am still a bit new to LabVIEW and for some reason the case structure's name is red. Could sombody tell me why this is happining and what can I do to fix this.
Unread 04-02-2014, 14:12
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Why is the case structure name red?
Because the case name does not match the data type of the input wired to the case selector.
ie. I have a case for "Fire Ball" and have a numeric wired to the case selector.
Unread 04-02-2014, 16:48
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
If you are using an enumeration for the states of your case structure, right click the state selector on the top of the structure and select "add case for every value". this will make your structure match your input.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
