Go to Post KISS does not mean that your goals and capabilities are "simple", it means that the way you achieve them is simple. - jspatz1 [more]
Unread 04-02-2014, 15:39
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
Rookie Year: 2012
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Equation for joystick input to Talons
hello all, we currently have decided to look into tweaking the operator controls of driving the robot. we currently have the joystick to Talon equation as a linear equation: y=x. What the joysticks get is sent to the talons. Each get values between -1 and 1. I'm sure you know this. y is what the Talons receive and x is the joystick input. What we're looking for is an equation that starts out slow, but once you get x to be around .4 to .6, y should be roughly equal to the x value. Past that, the y value should rapidly increase until you reach where x is around .75 or .8, where it should become very close to 1.
Example point table:
x,y
0,0
.1,.005
.5,.5
.6,.8
1,1
I know it may not be much, but I am also wondering what you may have used. this isn't really an issue with sensitivity, we are just looking to drive a little more slowly when the joysticks are lightly touched, but once they get past .6 or .7, drive very closely to full power if not full.
I understand we can do this with simple if statements, but an equation would make it... "flow"... much better.
Thank you for your help
