Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 05-02-2014, 01:39
James Lightfoot James Lightfoot is offline
Programming & Electrical Mentor
FRC #3737 (Rotoraptors)
Rookie Year: 2014
James Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really nice
Digital Side Car Wiring Of I/O & Solenoid Output Card
Hello,
1st year mentor and under the gun. I have a few quick questions about connecting I/O to the Digital Side Car and Solenoid card
1) Encoders [US Digital E4P-250-250-N-S-D-D-B encoder (am-0174)] connect to 2 GPIO points (Channels A & B), correct?
2) Are the GPIO points both Inputs and Outputs or just Inputs?
3) Do the GPIO points use the same connectors as the premade PWM cables?
A)If so, how do we connect "extra inputs & outputs (either via the GPIO
or Relay points) that do not come w/ premade cables?
3) We are using and ultrasonic sensor (Maxbotix MB7366) that has 3 output options (Analog Voltage, PWN, Serial). Can we connect the PWN singal to a GPIO as an input or do we have to use the Analog input route?
4) We are using an electromagnet that uses 12VDC. Can we connect that directly to Solenoid Output card or should I use an interposing relay (24VDC coil) and then use a NO contact to energize the electromagnet?
Thanks all,
Unread 05-02-2014, 09:24
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Digital Side Car Wiring Of I/O & Solenoid Output Card
You need 2 channels to use a quadrature encoder properly. One of the Channels will provide power in addition to being an input channel. The other is just a channel.
GPIO means General Purpose Input/Output. Each pin can be either input or output depending on software.
Yes, PWM outputs, GPIO, Relay outputs and Analog inputs all use the same connectors.
The Maxbotix sensor PWM output can be read by the GPIO. There may be more coding involved than using the Analog Voltage method.
It depends on how much current your electromagnet uses. If it's less than .75A, then you can use the Solenoid Breakout. If not, then you can use a Spike, which can handle up to 20A continuous.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 05-02-2014, 09:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
A few notes for your electromagnet...
Per Q&A 217
If the electromagnet causes movement, it is covered by R29. If the electromagnet only creates an attraction force, it is legal as long as it meets all other applicable rules.
So if your electromagnet causes movement, it's considered an electrical solenoid actuator, and per R29:
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 05-02-2014, 18:12
DonRotolo's Avatar
Back to humble
FRC #0832
4) We are using and ultrasonic sensor (Maxbotix MB7366) that has 3 output options (Analog Voltage, PWN, Serial). Can we connect the PWN singal to a GPIO as an input or do we have to use the Analog input route?
3A: Unfortunately you will have to wire it up yourself. We use 2 standard cables and cut / strip what we need, soldering the connections.
4: Strongly consider using the analog input instead. The sensor delivers a voltage that is linearly and directly proportional to distance. For example 2.56 V is 256 inches, 0.83 is 83 inches. Your voltages may vary.
Unread 23-02-2014, 03:46
Rookie Year: 2014
Thanks Don. I have a few quick question to clarify your last response.
3A1) For the Relay Outputs, I'm guessing that the A & B signal states [0 or 1] are controlled by the Java DigitalInput class, correct? Making pin A the PWM signal controlling a Spike Relay's FWD direction [depending on the code & wiring] a PWM signal of 1.0 to 1.5, correct?
3A2) For GPIO's, a discrete device like a Limit Switch will be "powered" by the available 5VDC on GPIO's pin 2, and the signal will connect to the GPIO's pin 1. Which leaves the GPIO's pin 3 tied to the DC Common bus,
3A3) For the Solenoid Breakout Board, the Outputs are sourcing also; hence, we would tie the Solenoid Output's + pin to the + terminal of a solenoid and the Solenoid Output's GND pin to a solenoids - terminal, correct?
I will not be surprised if tell I've all 3 of the above scenarios backwards.
4A) Will the voltage out on the "long range" ultrasonic sensor (3cm - 10m) also be linear but 5.3V = 5.3m?
Thank you very much.
Unread 23-02-2014, 06:56
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Use the Relay class - it works like this:
http://wpilib.screenstepslive.com/s/...hanisms-relays
If it is a limit switch (a simple mechanical closure), connect the common and normally open (or closed) contacts on the limit switch to the ground and signal connections of a digital I/O port. Then use the DigitalInput class to read the state.
Yes - this connection is correct. Use the Solenoid or DoubleSolenoid class to control the solenoids.
Check here: http://wpilib.screenstepslive.com/s/...ders-solenoids
and here: http://www.usfirst.org/sites/default...d_Breakout.pdf
We use this one: http://www.maxbotix.com/documents/MB1020_Datasheet.pdf
The datasheets for each are on the maxbotix web site. For the MB1020 the analog number is VCC/512 per inch.
Good Luck!
Fast, cheap or working - pick any two!
Unread 23-02-2014, 12:33
Rookie Year: 2014
Originally Posted by wireties View Post
If it is a limit switch (a simple mechanical closure), connect the common and normally open (or closed) contacts on the limit switch to the ground and signal connections of a digital I/O port. Then use the DigitalInput class to read the state.Good Luck!
Just so I make sure I get it:
GPIO Pin 1 to LS NO pin
GPIO Pin 3 to LS Common/Swing Point
GPIO pin 2 is not used
Correct or am I still getting it backwards?
Unread 23-02-2014, 16:01
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
This is correct. In this case it would not matter if you were getting it backwards. The switch just shorts the signals going into the DIO port. The DIO inputs are pulled up internally so it will read '1' if pins 1 and 3 are not shorted and '0' if pins 1 and 3 are shorted.
Good luck!
Unread 23-02-2014, 08:09
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Just a quick additional point.
The two Relay signal pins (one for Forward, and the other for Reverse) do not output a PWM signal.
It is a simple steady voltage when on, and zero volts when off.
